How can I move, all alone, a disabled motorcycle (heavy, no front wheel)
Discussion in 'Motorbike Technical Discussion' started by Joseph Donner, Jan 10, 2010.
  1. Joseph Donner
    terry Guest
    Ah milk crates .......................... yes.
    The newer ones, in now (supposedly) metric Canada, hold nine 2 litre
    milk cartons. Each will, typically, accommodate 20+ average dinner
    plates, up to 52 saucers, 24 cups etc. etc. And any variety of tools,
    spare parts , junk etc. etc.
    The older ones, designed for half gallons?, were much in demand at one
    time for storing 12 inch phonograph records!
    And also for standing on, or wangling something up/or down from the
    bed of a pickup. Motor cycle too heavy I would say.
    terry, Jan 11, 2010
  2. Joseph Donner
    Bob F Guest
    He didn't have a car, so that is unlikely.
    Bob F, Jan 11, 2010
  3. Joseph Donner
    Dean Hoffman Guest
    Kubotas are, or can be, all wheel drive. Actually, a lot of farm
    tractors are like that anymore.
    If the four large tires are on the back, it's for traction and
    flotation. The tire spacing is adjusted according to the owner's row
    spacing. It's pretty common to see six pulling tires on tractors now.
    Two in front and four in the rear.
    Plowing is pretty much the thing or the past. Most farmers are using
    some sort of minimum tillage. It saves money and is better for the
    soil. The organic matter stays on top the ground so it can limit wind
    and water erosion.
    I'm not too sure anyone is making a tricycle type front end for
    tractors now. They are more likely to tip over than the wide front ends.
    Dean Hoffman, Jan 12, 2010
  4. Joseph Donner
    paul c Guest
    I vote for protect the back and protect the bike. Rent truck from place
    that has dollies, as somebody else suggested, tilt the bike onto a
    moving blanket, some boards for a ramp, and borrow a "come-along"
    (sorry, don't know the correct name, it's like a giant-sized version of
    the small ratchets that some tie-downs have, you can pull a car
    singlehanded with a big one).
    paul c, Jan 12, 2010
  5. Joseph Donner
    paul c Guest
    Maybe remove battery, drain carbs if any, first and try to keep bike on
    a slight angle in transit so fuel and oil don't leak.
  6. Joseph Donner
    Smitty Two Guest
    Wow, over 30 replies thus far and I didn't see anyone ask what I see as
    a glaringly relevant question: How far do you have to move it?
    Smitty Two, Jan 13, 2010
  7. Joseph Donner
    S'mee Guest
    where would the fun in that be...I'm sure that super genius gael the
    fail will have a perfectly wrong and overly failure ridden answer. Me
    I've never had a problem moveing any motorcycle I've owned. Whether
    it's was not running/missing parts or running just fine. I ought to
    have handicap placard...who needs that unless they are a
    quardarplegic? sheesh...the op needs to man up and figure it out.
    S'mee, Jan 13, 2010
  8. Joseph Donner
    TwoGuns Guest
    Is the bike chain driven?
    If it is you can take the chain off and tow it on its back wheel.
    Rent or borrow a truck with the bumper hitch that has the slide in
    shaft. Find a bolt that is the same diameter as your front axle but
    two or three inches longer than your axle.Use a bumper jack or
    scissors jack to lift the front end up. Straddle the hitch and slide
    the replacement axle bolt through a hole in the hitch bar and use
    washers to snug up the axle bolt and pin the hitch bar into the
    receiver. If you have a chain drive you just take the chain off. If
    you have a shaft drive you might want to check with the maker of your
    bike to see if towing with the rear wheel on the ground will hurt. You
    might be able to tow it in NEUTRAL for a few miles without any damage.
    Your state may require a safety chain or better yet a safety strap so
    you don't scratch any finish on your bike.
    I have done this by myself so I know it works.
    DL
    TwoGuns, Jan 29, 2010
