Hose source
Discussion in 'Classic Motorbikes' started by Ant - 441cc, Jun 15, 2006.
  1. Ant - 441cc
    Ant - 441cc Guest
    I need to source some hose for fuel and cracnk breathing. I'd like to
    get the clear stuff with the sort of criss cross thread reinforcement
    thru it to suit 6 and 10mm spigots. Anyone know of a source?
    Ants
  2. Ant - 441cc
    Ant - 441cc Guest
  3. Ant - 441cc
    gazzafield Guest
    gazzafield, Jun 15, 2006
  4. I detest that stuff. after contact with fuel for any length of time it
    becomes rock hard.
    Austin Shackles, Jun 15, 2006
  5. Ant - 441cc
    Roger Hunt Guest
    I had a loop hanging on a beam in the garage that managed to turn
    rockard without contact with anything. Probably genuine special Atco
    self-hardening fuel hose.
    And these loops of tube very often acquire a tenant, like a spider or
    earwig, which does little for fuel flow if overlooked and is horrible
    when sucked into the mouth.
    Roger Hunt, Jun 15, 2006
  6. Ant - 441cc
    Famous for immolating air-cooled VWs of various types.
    platypus, Jun 15, 2006
  7. Ant - 441cc
    Shep© Guest
    B&Q.They have it on rolls.
    Yes it yellows and gets hard after a while so buy 2 metres for 2 quid.
    HTH :)
    Shep©, Jun 17, 2006
  8. Ant - 441cc
    A.Clews Guest
    Thus spake Roger Hunt () unto the assembled multitudes:
    Not thought about stuffing something (paper, plastic, old ear-protectors)
    in the ends of the tube to keep it clear, then?
    A.Clews, Jun 17, 2006
  9. Ant - 441cc
    said...
    Will you please stop coming up with these useful tips, you're making me
    feel quite inadequate.
    Lozzo, Jun 17, 2006
  10. On Sat, 17 Jun 2006 07:48:35 +0100, Lozzo <>
    Nowadays there's Viagra for that.
    Dr Ivan D. Reid, Jun 17, 2006
  11. Ant - 441cc
    With an old ear-protector stuffed up the end of his hose, he won't need
    Viagra.
    platypus, Jun 17, 2006
  12. Ant - 441cc
    If you mean the clear PVC stuff don't use it for fuel (or oil for that
    matter) as it goes hard and then leaks. It also looks shit.
    Just go into a half decent Motor Factors (this doesn't mean Halfords) and
    buy 8 or 10mm fuel line by the metre.
    sweller, Jun 17, 2006
  13. Ant - 441cc
    Roger Hunt Guest
    Obviously not - far too sensible for me, and I would probably poke
    it down too far and make an immovable blockage necessitating chopping
    a bit off the tube and leaving a length that is now too short for the
    job. :)
    Roger Hunt, Jun 18, 2006
  14. Ant - 441cc
    A.Clews Guest
    Alternative I guess is to get a piece of dowel that's a tight fit in the
    tube, then stuff it half way into both ends, join both ends together
    and stow the resultant assembly. Sorted!
    <closes shed door, pours a Guinness, smokes a rollup [1]>
    [1] oops, remembers doesn't smoke
    A.Clews, Jun 20, 2006
  15. Ant - 441cc
    A.Clews Guest
    Thus spake Dr Ivan D. Reid () unto the assembled multitudes:
    That's an expensive way of sealing the ends of exposed bits of tube ;-)
  16. Ant - 441cc
    Guest Guest
    I immediately thought of 'vasectomy'.
    Scary how the mind works sometimes.
    Regards,
    Simonm.
    Guest, Jun 21, 2006
  17. Ant - 441cc
    Roger Hunt Guest
    Okie-dokie. Good idea. Mine dew, that involves all the complication and
    challenge of finding that bit of suitable dowel.
    No prob - I'll swap you a pack of cyber-Old Holborn for a cyber-pint of
    cyber-Guinness, because I smoke but don't drrink. Sorted!
    Roger Hunt, Jun 21, 2006
  18. Ant - 441cc
    A.Clews Guest
    I guess it depends how unwelcome the tenants are in your tube ends ;-)
    Pleasure doing business with you squire ;-)
    A.Clews, Jun 24, 2006
