horns barely audible
Discussion in 'Motorbike Technical Discussion' started by vt1100, Jul 9, 2006.
  1. vt1100
    vt1100 Guest
    I recently got caught riding in a heavy rainstorm. Later that day after the
    skies cleared I went riding again. I noticed that when I used the horns they
    were barely audible. I figured they got wet and would be OK after they dried
    out. That was a week ago and they are still very faint sounding. I've been
    riding for several years and had six different bikes and this is the first time
    it's happenend to me. Any ideas? These are after market horns that have a
    car-like sound to them. I bought the bike (85 vt1100) used and they were already
    on it. TIA
    vt1100, Jul 9, 2006
  2. vt1100
    fweddybear Guest
    Not sure if they have a small screw on them or not (there are on mine)
    but I had a similar problem and all I had to do was to turn out the
    adjusting screw and they both sound fine now....
    Fwed
    fweddybear, Jul 9, 2006
  3. vt1100
    vt1100 Guest
    Thanks...I'll check that out.
    vt1100
    vt1100, Jul 9, 2006
  4. vt1100
    John Johnson Guest
    Very likely, unless you wired them directly to the battery via a relay.
    The stock wiring harness is sized to the stock horns, so if your new
    horns draw significantly more current you're not going to get sufficient
    current.
    Later,
    John
    John Johnson, Jul 9, 2006
  5. vt1100
    Don Fearn Guest
    Good writeup, Gene! It reminds me of the notes I've sent to several
    folk about installing LOUD horns on their motorcycles, although I
    never went as far as having an impulse relay on any of my
    installations -- hmmmmmm . . . interesting idea . . . .
    Two observations:
    1) There are better airhorns than Wolo. Here are my favorites to date:
    http://tinyurl.com/emty7
    (http://www.adventurersworkshop.com/...=8007850002033&Category_Code=Stebel_Air_Horns)
    -or-
    http://www.twistedthrottle.com/trade/productview/2137/539/
    These suckers are LOUD and very compact. I have them on my R1100S,
    where conventional air horns are a difficult fit, and on my xB cage. I
    really like them, and they're relatively cheap.
    B) You say:
    I would say that ANY horns can't prevent that, so DON'T DEPEND ON YOUR
    HORNS!!!
    It's nice to have horns that sound like they'd blow away a
    Freightliner, but any cage driven by a typical BDC can take you out
    regardless of how loud you are. Always have an escape route in case
    your horns DON'T wake the dead . . . .
    pooder was here in a horny way
    Don Fearn, Jul 11, 2006
  6. Yes, measure the voltage across the horn terminals when they are
    operated and compare that to what you measure directly across the battery.
    The difference is the voltage drop. Better to use an analogue rather than
    digital meter because there will be considerable ripple and spikes due to
    the way the horn works.
    Dr Ivan D. Reid, Jul 11, 2006
  7. vt1100
    Don Fearn Guest
    Probably not. Motorcycles come with notoriously weak meepers compared
    to aftermarket horns; especially Fiamms and their ilk. A relay is
    always recommended.
    I wouldn't do any of those things; I'd run a separate fused wire
    (14-guage or heavier preferred) from the battery and use that current
    switched through a relay to power the horns. Then you're getting the
    maximum from the horns at the least risk to the horn button and the
    rest of the wiring.
    There's a pretty dang good writeup at:
    <http://home.cfl.rr.com/genecash/air_horns/air_horn_wiring.html>
    (You can just bypass the impulse relay if you don't want that feature
    and you'll still get all the volume your horns will produce.)
    I also have a text-only writeup that I could send you if you want. I'm
    pooderatcharterdotnet or something like that . . . .
    pooder was here still being horny
    Don Fearn, Jul 12, 2006
  8. vt1100
    Don Fearn Guest
    I'm glad to hear (pun intended) that. I thought that might be the
    case, but I wanted to make sure that no one gets complacent because
    they have loud horns and winds up as a statistic. Extra time is what I
    hope for from horns and anything else is a bonus.....
    It's selective hearing/vision at work. We tend to hear and see what we
    expect to hear and see, and anything else can get filtered out. That's
    one of the scary realities about riding a motorcycle . . . . .
    pooder was here sneaking in another observation
  9. What a *lovely* expression :)))
    Meep! Meep! Yes, exactly like a dying bike horn.
    The Older Gentleman, Jul 12, 2006
  10. vt1100
    Mark Guest
    That's why I think every bike should have (at least) 2 headlights on
    front so you "look like" a car approaching... also with only one light
    is hard for other folks to tell how far it is and how fast it is
    approaching...
    Mark
    Mark, Jul 18, 2006
