Honda, you thieving bar-stewards - part deux
Discussion in 'UK Motorcycles' started by JackH, Nov 7, 2008.
  1. JackH
    JackH Guest
    Having decided to just 'rebuild the bloody thing' anyway yesterday evening,
    I popped down to my friendly (1) local Honda dealer this morning to order a
    piston kit for the rear brake master cylinder for the VFR.
    So... how much do you reckon this was, together with two small exhaust
    clamps for where the rear downpipes meet the main system, and two gaskets
    for the same joints?
    I would have suggest a reasonable price would have been £45ish.
    Just a shade under *£90* ffs, and for that you don't even get the bolts to
    do the clamps up with.
    I had to change the front discs and pads, and a rear wheel bearing on the
    Nova last week and got change from £45, and yes, I appreciate the concept of
    'the economy of scale', but I still reckon Honda are taking the piss.
    (1) I say friendly - he always greets me with a smile now, which I'm sure is
    nothing to do with the distinct possibility I'm about to be torn yet another
    new arsehole. ;-)
    JackH
    98 Honda VFR800FiW
    05 Sachs Madass
    03 VW Passat TDI Sport
    89 Vauxhall Nova 1.3 Pearl
    JackH, Nov 7, 2008
  2. JackH
    Cane Guest
    Damn right :)
    Cane, Nov 7, 2008
  3. JackH
    Cane Guest
    Through gritted teeth, thinking 'here comes that pikey **** again who
    thinks everything should be half price'
    Cane, Nov 7, 2008
  4. JackH
    JackH Guest
    £5 for the Merc, Mister?
    Slitting me own throat an all that...
    JackH
    98 Honda VFR800FiW
    05 Sachs Madass
    JackH, Nov 7, 2008
  5. JackH
    Simon Wilson Guest
    oops just read your other thread, looks like you tried DS (or thought
    about it) already.
    As you were.
    Simon Wilson, Nov 7, 2008
  6. JackH
    JackH Guest
    Had a look on their website last night - by the time I'd paid the postage
    they'd have been dearer.
    However, I agree... they're very reasonable on some parts, as in, cheaper in
    some instances for original Honda stuff than I've seen it go for secondhand
    on eBay.
    JackH
    98 Honda VFR800FiW
    05 Sachs Madass
    JackH, Nov 7, 2008
  7. JackH
    Cane Guest
    Careful, I'm tempted if it's cash :)
    Cane, Nov 7, 2008
  8. JackH
    JackH Guest
    The bike stood for about two years before I bought it and it's therefore not
    unreasonable to assume, given the symptoms before I made things worse,
    suggested that the seals might have started to deteriorate in that time.
    Mechanic matey whose workshop I'm using also reckoned it could be partly
    down to an inefficient master cylinder, so I might as well do them, not
    least because if I get the job I'm going for on Monday, I'll be using it to
    do a reasonable commute on.
    FWIW, the braking bits were £40s worth of the bill today, the other £49 was
    for the exhaust bits.
    JackH
    98 Honda VFR800FiW
    05 Sachs Madass
    JackH, Nov 7, 2008
  9. JackH
    JackH Guest
    Depends on your riding style.
    Especially around town.
    JackH
    98 Honda VFR800FiW
    05 Sachs Madass
    JackH, Nov 7, 2008
  10. JackH
    JackH Guest
    <reaches down the back of the sofa>
    Ew... I think Whinging Courier has left his calling card.
    JackH
    98 Honda VFR800FiW
    05 Sachs Madass
    JackH, Nov 7, 2008
  11. JackH
    TOG@Toil Guest
    Um, no, not really.
    I think your mechanic matey's advice is best ignored.
    TOG@Toil, Nov 7, 2008
  12. JackH
    JackH Guest
    I'll have the bestest brakes in the world when they're done.
    Oh, and FOYRNB! ;-)
    JackH
    98 Honda VFR800FiW
    05 Sachs Madass
    JackH, Nov 7, 2008
  13. JackH
    Pete Fisher Guest
    I had a bit of trouble with the front brake on the hill climb Morini
    earlier this year. I put a new braided line on it and worked through
    loads of new fluid. Seemed fine if a little wooden, but after the first
    snowy Hartland the lever went floppy and wasn't returning properly.
    I thought might have to do a caliper and master cylinder rebuild
    (Grimeca with seals at least 20 years old). Many sequences of caliper
    piston nearly popped out then forced back in followed by another load of
    new fluid got it working properly again (as well as they ever did
    anyway). Still a bit wooden, but I'm told braided lines sometimes have
    that effect on older stuff. I have some new pads to try next season, but
    you can only get Goldfren these days which aren't highly rated.
    | Pete Fisher at Home: |
    Pete Fisher, Nov 7, 2008
  14. JackH
    Simon Wilson Guest
    Might be grot/corrosion behind the seals?
    The rear brake on my Pan definitely had a very wooden feel to it when I
    got it. Since I don't use it much it didn't really bother me but I did
    think that the caliper/pistons could do with some attention at some
    time. It passed MOT's ok so again I didn't really worry about it. Then
    one day I decided the brake pedal spindle itself looked like it could
    with a bit of lube. Sprayed some stuff on it and now the rear brake's
    got some feel to it. Why don't I look for the simple things first?
  15. JackH
    Pete Fisher Guest
    The master cylinder moving parts all move freely when there is no fluid
    in the system. I don't particularly want to do a full master cylinder
    and caliper strip if I can help it, but it may come to it. The last
    time the master cylinder was done (by a dealer) it took ages to settle
    down. Such a job is a bit beyond 'simple' for me. The brake wasn't
    wooden before I put the braided line on and worked pretty well. Just
    didn't fancy relying on a 25 year old hose.
  16. JackH
    You're a fool, I offered a grand the other week and got no response
    Lozzo, Nov 7, 2008
  17. JackH
    If they had, it'd be leaking fluid.
    Champ, Nov 8, 2008
  18. JackH
    Pete Fisher Guest
    When I had to have the master cylinder seals done on the Morini years
    ago IIRC there was no leakage at all. It was just crap (well more than
    usual) and no amount of bleeding would sort it out.
    Pete Fisher, Nov 8, 2008
  19. Possibly gunge in 'oles, but you'll see it as you strip it.
    Probably that the seals are a bit past their best, and lost their knife
    edge, which is to be expected on anything more than a couple of years
    old. Seal kits, especially for master cylinders, aren't fitted often
    enough, and should be regarded as high-mileage service items.
    Fortunately, such is the design of seals that applied pressure spreads
    them out against the cylinder wall, for which lazy cunts can be truly
    grateful. This results in a bit of lost motion though, which he probably
    means.
    Grimly Curmudgeon, Nov 8, 2008
  20. JackH
    JackH Guest
    Ok... going back to why I originally decided to fettle the system, is
    because the bite on the brakes when you applied the rear was woefully
    inadequate but consistent - having only recently sold on the ex SteveH VFR
    which had superb brakes all round, I know what they should feel like when in
    good health, hence why I knew for sure the rear on this one isn't 100%.
    So that's why I went down the route refurbishing the rear caliper... and now
    we have this issue, which it does sound like is to do with air in the
    system, but rather than keep doing one part then finding they still don't
    work properly, I've decided for the sake of £40 for the piston kit, I'm
    eliminating what could still be part of the problem.
    Hopefully, that'll be the end of it on Tuesday, as that's when the parts are
    due to arrive, and I can fit them. :)
    JackH
    98 Honda VFR800FiW
    05 Sachs Madass
    JackH, Nov 8, 2008
