Honda VT700C fuel shut off relay
Discussion in 'Motorbike Technical Discussion' started by K H, Jul 12, 2003.
  1. K H
    K H Guest
    The fuel pump only works on my 1985 VT700C if I connect it directly to the
    battery. It appears that the fuel shut off relay (tip over switch) is
    defective. How can I test the relay? An ohm meter shows that all (3)
    contacts are open no matter what the orientation the switch. I believe the
    correct orientation is standing tall with the contacts at the bottom. What
    is the third contact on the relay for? My wiring diagram shows it going to
    the ignition unit.
    Thanks,
    KH
    K H, Jul 12, 2003
  2. You made refference to the thrid contact in the relay, that lead should
    be the one coming from the Ignition switch, and it should have voltage
    when the key is on. One of the other leads should be going to the fuel
    pump and with the key in the on postion, it will show battery voltage.
    The last lead should have batter voltage all the time even with the key
    in the off postion. If you do not have battery voltage going to the fuel
    pump off that lead and yet the other two have voltage with the key
    switch on, then yes you do have a problem within the relay as far as the
    tip over switch with in the relay.
    Hope that helps you out.
    David
    95 Nighthawk 750, Jul 16, 2003
  3. K H
    K H Guest
    Thank you for responding to my question.
    My problem appears to be a bad batch of fuel. The simptoms were fuel
    starvation the day after I filled the tank and drove 30 miles. Draining the
    fuel system and filling with fresh fuel has reduced the problem. Another
    fill should eliminate it. However, during my trouble shooting activities I
    got interested in the fuel cut switch. I have two of these units now and
    they both behave the same way. Testing with an ohm meter shows that there
    is no connection between any of the contacts in any orientation. When the
    unit is installed, I measure the following voltages. There are no voltages
    on any of the leads with the key off. The fuel pump gives one click when I
    turn on the key. 0 volts on the lead to the pump and 12+ volts on the other
    two leads. When I start the engine, approximately 4 volts appears on the
    pump lead. I read somewhere that the fuel pump will not run when there is
    no oil pressure. The voltages do not seem effected by the orientation of
    the switch. Interesting behavior for a tip over switch Any more thoughts
    on what is going on?
    KH
    K H, Jul 17, 2003
  4. Hey again,
    After reading what you had wrote, I can only come up with a couple
    ideas, you stated that you had 0 volts to the fuel pump lead off the
    relay, and then you stated that after starting it you had 4 volts at the
    fuel pump, I am assuming you that was not with the relay in the circuit
    at all when you had the 4 volts? If your going to check voltage supply
    to your fuel pump, you have to disconnect the lead going to the pump to
    get the amount of voltage, because if your fuel pump has an internal
    short no matter how small the voltage reading will drop drastically, so
    check it with the lead off the fuel pump. If it shows battery voltage
    approx 12V with the lead off and 4V with the lead on, you most
    definitely have a fuel pump problem. but if there is no voltage going to
    the fuel while key on and maybe also trying to start the machine as
    well, I was looking at a wiring diagram and the one wire comes from an
    ignition module which might need to sense that the engine is cranking
    for the fuel pump to operate.
    So to recap here, check voltage at the fuel pump with it disconnected
    from the fuel pump,and as well with it connected. if it is both 0 volts
    then replace the relay, if it is battery voltage with it disconnected
    and 4 volts with it connected, then I would replace the fuel pump.
    BUT REMEMBER TO CRANK THE ENGINE OVER WHEN CHECKING THE VOLTAGE GOING TO
    THE FUEL PUMP!
    I looked for a wiring diagram for your bike, I found one but the years
    and model were not exactly right on but I thought it might be close, and
    it even had the wire colors so as you could compare yours to the diagram.
    Here is the link
    http://www.smokeriders.com/diagrams/index.php?show=Honda/98-00_VT750C_CD_ACE.gif
    Here is the page for a list of other models and other makes of bikes to
    look though.
    http://smokeriders.com/Technical/wiring_diagrams/wiring_diagrams.html
    I hope that is of some more help for you,
    David
    95 Nighthawk 750, Jul 17, 2003
  5. Hey again,
    at all you had the 4 volts? If your going to check voltage supply to
    your fuel pump, you have to disconnect the lead going to the pump to get
    the amount of voltage, because if your fuel pump has an internal short
    no matter how small the voltage reading will drop drastically, so check
    it with the lead off the fuel pump. If it shows battery voltage approx
    12V with the lead off and 4V with the lead on, you most deffinetly have
    a fuel pump problem. but if there is no voltage going to the fuel while
    key on and maybe also trying to start the machine as well, I was looking
    at a wiring diagram and the one wire comes from an ignition module which
    might need to sense that the engine is cranking for the fuel pump to
    operate.
    So to recap here, check voltage at the fuel pump with it disconneted
    THE FUEL PUMP!
    Here is the link
    look though.
    David
