hi i have bought a non running 1983 vf750f and after some hours of swearing and kicking the thing i cant get it to run i after cleaning and setting the carbs up and then checking the ignition timing i have found that the previous owner must have had the heads of at some point because the valve timing is wrong. i set the cams on the rear cylinder to line up with all the timing marks but the front cylinder timing marks seem to be wrong the valves hit the piston if you linr the marks up. i was told that the marks on the front cylinder cams are wrong and that you are supposed to mark the cams before you take them off unfortunatly the previous knit wit didnt put the cams to the corect timing and he did not mark them. so can anyone tell me what the timing should be for the front cylinders.
