Honda spare parts?
Discussion in 'Australian Motorcycles' started by Shaw Goh \(NetPlus Micro Computers\), Feb 11, 2004.
  1. Looks like the Viffer has the dreaded fried regulator/rectifier and I would
    need to get a replacement.
    Is my only option to buy a Honda replacement from Honda dealers at $300+?
    Or is there an alternative item/place that would save a few dollars?
  2. Contact Jack @ CAE (City Auto Electrics) in Coburg (03)93506677 for one of his
    beefier and modded reg/recs for your VFR.
    I got him to install mine, but if you're not in Melbourne I'm pretty sure he
    does mailorder.
    Good luck
    tm
    "Pepito" '96 VFR750 with high-rise Staintune.
    Have a look:
    http://ausvfr.ampersand.asn.au/gallery/tonys_yellow_vfr
    Have a listen:
    http://www.cs.wisc.edu/~john/vfr/VFRTune.wav
    Pepito pepito, Feb 11, 2004
  3. Shaw Goh \(NetPlus Micro Computers\)
    Dave_H Guest
    Before you go and do that, I had what I thought was a dead
    rectifier/regulator on my honda a while ago, the more I revved the
    engine, the dimmer the headlight. We measured it and the harder it
    revved, the lower the voltage
    however...
    turned out to be the battery! The R/R acts in a strange way. If the
    battery cant muster sufficient charge , the R/R actually reduces the
    voltage. I dont understand electronics that well unfortunatley. New
    battery and all was well!
    I'd hate for you to spend lots of $$$ for no reason. try a
    replacement battery or at least hooking it up to another bike with
    jumper leads.
    If it is the R/R try a bike wrecker, they often stock non genuine new
    parts a lot cheaper than honda's brand name ones.
    Dave_H, Feb 11, 2004
  4. Thanks TM, $200 + postage - sure beats $300+!
    The discrepancy in pricing amazes me. I bought a new battery from battery
    dealer for $60. Honda dealers wanted $120.
    Shaw Goh \(NetPlus Micro Computers\), Feb 12, 2004
  5. I've done that... Had a nice 2 hour ride into the country with new battery
    installed, only to have the bike stall and flat battery at the first traffic
    light. A new battery gives a dangerous false sense of security.
  6. Shaw Goh \(NetPlus Micro Computers\)
    Nev.. Guest
    The discrepancy in pricing amazes me too. I can get a new Holden for $37,000
    but the Ferrari dealer wanted $370,000 for the car in his showroom.
    Nev..
    '03 ZX12R
    '02 CBR1100XX
    Got to a library, find the section with the economics books, find a reasonably
    thick one and read the chapters on "supply and demand" and "economies of
    scale"... and any others you find interesting.
    Nev.., Feb 12, 2004
  7. Shaw Goh \(NetPlus Micro Computers\)
    FuTAnT Guest
    Heya
    I suggest you go and check out the forms etc at http://www.ozvfr.net/ first
    for some reading information. From my previous scanning the VFR's are
    notorious for the regs overheating and hence clapping out. If it is fried go
    an aftermarket option (around $150) and then you can also fit a small
    heatsink and fan set up similar to that used on power supplies or computer
    chips (depending on the mating surfaces etc). I'm sure there is some VFR
    tech heads in here that have all the gory details. I've searched on VFR's
    before on the net and found various links to the reg/rect problems and
    solutions to solve the heat/failure problem.
    Cam
    '03 954
    FuTAnT, Feb 12, 2004
  8. Shaw Goh \(NetPlus Micro Computers\)
    Johnnie5 Guest
    $65 for a used r/r at the wreckers versus $450 from ducati
    where do you think batteries come from
    go and price bearings and see even more of a difference
    eliminate the middle man
    Johnnie5, Feb 12, 2004
