Honda Shadow Sabre and Shadow Spirit
Discussion in 'Texas Bikers' started by Lynn McGuire, Dec 6, 2003.
  1. Lynn McGuire
    Lynn McGuire Guest
    I visited Wild West Honda in Katy yesterday and really liked the Honda
    Shadow Sabre that they had on the showroom floor. However, I visited
    them to see the Honda Shadow Spirit (which they did not have built yet).
    Both are Vtwin 45 degree 1100s, dual 36 mm carbs, 8.0:1, 5 speed shaft
    drive, front 316 mm disk brake, rear 170/80-15 tire and 4.2 gal gas tanks.
    The sabre has a rear 276 mm disk brake (+++), a front 120/90-18 tire,
    a seat height of 27.2", a weight of 573 lbs, a 4.7" front travel fork and a
    2004 MSRP of $8299. The spirit has a rear drum brake (---), a front
    110/90-19 tire, a seat height of 28.7", a weight of 553 lbs, a 6.3" front
    travel fork and a 2004 MSRP of $8099. The sabre is kinda retro look
    whereas the spirit is kinda classic chopper look.
    Of course, no test rides !
    Here are the URLs for both:
    http://powersports.honda.com/motorc...hadow+Spirit&ModelYear=2004&ModelId=VT1100C14
    http://powersports.honda.com/motorc...Shadow+Sabre&ModelYear=2004&ModelId=VT1100C24
    I was wondering if anyone had informed opinions betweenst these two
    great looking bikes ? A fellow looker told me he had a 2002 sabre and
    loved it, especially the rear disk brake which the spirit does not have. He
    also told me that the dealer should be willing to drop the MSRP by $500
    to $600.
    Thanks,
    Lynn McGuire
  2. <snip specs>
    nowhere do they say the rake and trail. most important spec as to how
    it's likely to handle without actually riding it. something to ask the
    salesguy or have him find out for you. that will also tell you if they
    are the same frame with different tin and wheels to separate them or if
    they actually have different specs there. they probably are the same
    frame, but never hurts to find out.
    try honda of houston on bingle and northwest honda/ducati just for grins.
    there may be used models you could take for a spin.
    softail standard knockoff
    fatboy knockoff
    no informed opinion here, but this is usenet so who cares... <heh>
    larger front tire, ie, not the 19" wheel, may give a little better bite
    for braking. are the front brakes the same on each? that's the
    important one. a drum on the rear isn't horrible and is less
    maintaince. no problem with drum brakes at all.
    after that, it's what fits you most comfortably.
    jam
    '73 R75/5 Toaster (not for sale)
    '99 R1100RT (in use)
    '00 FLHRCI (sold!)
    Iron Butt Assoc, WATR 3X, EIEIO, AEIOU etc blah blah
    another viewer, Dec 6, 2003
  3. Lynn McGuire
    Lynn McGuire Guest
    I think the Sabre looks better and I do prefer disk brakes over drum brakes.
    For some reason the chopper look (spirit) does more for me than
    the retro look (sabre).
    That is what I am thinking also. So, I am leaning towards the
    spirit on looks (and 2nd person comfort since I am hoping to
    persuade my wife to take short trips with me). I will give the
    spirit the rump test next week hopefully. I do like the Honda
    special financing that is available until 12/31/03, makes it easy
    to get into either bike.
    Thanks,
    Lynn
    Lynn McGuire, Dec 7, 2003
  4. Lynn McGuire
    Lynn McGuire Guest
    Spirit: 41mm fork; 6.3-inch travel
    Sabre: 41mm fork; 4.7-inch travel
    Will do that !
    I think that they are the same front brake.
    The Sabre was OK, have yet to try the Spirit.
    Thanks,
    Lynn
  5. Lynn McGuire
    Brian Walker Guest
    ARE YOU INSANE!?
    Honda doesn't make a single piece that's a "knockoff" to ANY Harley.
    There's ZERO in common between Honda and Harley.
    The closest I've seen/heard of Honda being "knockoff" to a Harley was
    when I heard a mid-90s ACE with V&H pipes sound exactly like a
    Harley...even had the Harley frontal bounce. But, unlike their
    "so-called" lawsuit, I don't believe ANYONE can trademark a "sound".
    Brian Walker, Dec 7, 2003
  6. Spirit: 41mm fork; 6.3-inch travel
    Sabre: 41mm fork; 4.7-inch travel[/QUOTE]
    obviously the spirit should have a more plush ride. are they adjustable?
    does it matter? <g>
    rake is the angle of the steering axis (generally but not necessarily
    the forks) measured in degrees off vertical towards the rider. trail is
    the distance of the imaginary line from the center of the front axle
    where it would hit the ground directly below itself, to where the forks
    would hit the ground in front of the front wheel if they extended to the
    ground. kapiche? it's a usually quoted spec for most bikes.
    generally, the greater the rake, the more straight line stable and less
    quick turning the bike. the inverse is true. longer trail = more stable.
    corrections are welcomed if i am wrong in my definition.
    see
    http://home.iprimus.com.au/stevebm/steering.htm
    for a quick over view.
    and ya know what? don't obsess over the bike, find sumpin you like and
    go ride.
    jam
    '00 FLHRCI (sold!)
    another viewer, Dec 7, 2003
  7. Lynn McGuire
    fullstate Guest
    I missed part of this conversation, but one of the bikes had discs and
    one of them had drums. I'm a disc-brake fan myself. The drums aren't
    worth a crap. Again, it comes down to what YOU like and how hard you
    ride the bike, though.
    One thing I wanted to mention since it looks like you might buy new -
    the law in Texas (Consumer Protection Act) allows you to return
    ANYTHING you buy new within 48 hours of purchase. Now, you might look
    up the exact time period (it might be 24 or 72 hours for instance),
    but it basically means that the dealer HAS to take the bike back if
    you get it out and don't like it. It doesn't mean that they don't
    have to give you a hassle about doing it, though. Most dealers won't
    tell you about it, but they will offer to let you have the bike for a
    day to see if you like it, provided that you do all the paper work and
    buy the bike. Same thing.
    Obviously I am not a lawyer and I don't know all the dynamics of this
    law, but you might want to look it up if you think you might change
    your mind on the bike.
    --Fullstate
    fullstate, Dec 7, 2003
  8. ARE YOU INSANE!?[/QUOTE]
    yer right. i went back and looked again.
    the spirit isn't a knockoff of the Softail at all.
    the spirit is a knockoff of the Dyna series.
    my mistake, shoulda picked up on the exposed rear shocks the first time.
    ;^D
    jam
    '00 FLHRCI (sold!)
