Honda keys
Discussion in 'UK Motorcycles' started by Vass, Mar 25, 2011.
  1. Vass
    Vass Guest
    Buying a nice 2009 CBR125R for Mrs Vass
    the owner has 2 keys not 3 and I forgot to ask
    not seen the other key, just a blue one in the bike tonight
    Am I right in thinking there is an all important red key for honda to copy
    if needed?
    if missing is it a big enough reason to walk away?
    Bikes lovely and good price.
    TIA
    Vass, Mar 25, 2011
  2. Vass
    Nope
    http://ww1.honda.co.uk/news/motorcycles/20070308.html
    Just like my 1999 CBR6, there are 2 keys issued with a bike. They have bog
    standard RFID chips in them and a Honda dealer can pair another key to the
    bike if needed.
    wessie, Mar 25, 2011
  3. Vass
    SteveH Guest
    You can probably also get them cloned at Timpsons, too.
    SteveH, Mar 25, 2011
  4. Vass
    WillF Guest
    I'm interested if that's the case- i recently bought a honda bike with
    only one key. To obtain a second i had to
    1. Visit local dealer to buy blank
    2. Take said blank to a key cutter to copy physical attributes of the
    key
    3. Return to honda to have them remove fuel tank and do some trickery
    to have ECU recognise the new key
    All in all about £60 and 2-3 hours of time, totally ott i felt.
    Will
    WillF, Mar 25, 2011
  5. Vass
  6. Vass
    Tim Guest
    Hmm... In my admittedly limited experience, there's a gap netween what
    Timpsons think they can do and what they can actually do.
    Most modern keys need to be "paired" with the vehicle's immobiliser by the
    main dealer or an appropriate specialist.
    Tim
    Tim, Mar 25, 2011
  7. Vass
    SteveH Guest
    Not quite right - remote keys for alarm and locking systems need this.
    If you have a plain transponder key, then cloning works.
    This will be the case with almost every motorbike key.
  8. Vass
    tember.org:
    The seem to be claiming they can clone RFID tags. If that is possible[1]
    then I don't see why the vehicle's ECU would need to be played with.
    [1] loads of hits on google suggest it is
  9. Vass
    SteveH Guest
    I had a Fiat key cloned by them last year - one of the CODE transponder
    keys which Fiat were incredibly proud of back in the mid 90s.
    They reckoned, at the time, that the only way to get a spare key was to
    take your car and the red 'master' to them - this later turned out to be
    bullshit when Timpsons got their cloning kit.
  10. Vass
    Tim Guest
    Fair enough. My experience has been restricted to the family cars.
    Tim
    Tim, Mar 25, 2011
  11. Vass
    Salad Dodger Guest
    The one on Cannon St won't do motorcycle keys, even a boring old blank
    so Linda can open the Wing's topbox - luckily, the Monument one will.
    Salad Dodger, Mar 25, 2011
  12. Vass
    Thomas Guest
    I just had a spare made for my BMW. Since the bike isn't here, I
    showed the dealer proof of ID and ownership and the VIN. Less than 48
    hours later, a new key was in my hands. It cost $50. Of course, if it
    didn't have the coding, it would be a fraction of that. Progress.
    Thomas, Mar 26, 2011
  13. Vass
    SIRPip Guest
    While you're there, Steve: I had a battery charging issue with the
    Vectra over Christmas and this resulted in the thing going completely
    flat twice. By completely flat, I mean flat enough to zero the trip
    meter part of the odometer.
    I'm now reduced to manually unlocking the thing, as the remote
    unlocking keys seem to have failed: one went and I changed the
    batteries in it to no avail, but the spare worked so I swapped them
    over - now the erstwhile spare has packed it in too. It was only
    recently that I put two and two together and realised that the loss of
    function related to the very cold spells when the car battery went flat.
    Does this mean I've no alternative but to go to a Vx dealer and pay
    stupid amounts of money? I'll forgo the luxury of bipping the thing
    and stick to keying it each time, if that's the case.
    SIRPip, Mar 26, 2011
  14. Some of the manufacturers use rolling coded systems now which need to
    be programmed to the ecu/ key
    I know timpsons cant do some of the citroen/pug or fiat keys .
    steve robinson, Mar 26, 2011
  15. Vass
    SteveH Guest
    Try putting the key in the ignition, turning 'on', but not starting the
    car, then pressing and holding the 'door open' button - that, I believe,
    will re-sync an existing key / fob to the car.
    SteveH, Mar 26, 2011
  16. Vass
    SIRPip Guest
    Ah, good old boy. I'll give that a go in a minute. I was hoping you'd
    come up with something as simple as that.
  17. Vass
    Scraggy Guest
    <awaits 'car immobile' post>
    Scraggy, Mar 26, 2011
  18. Vass
    SIRPip Guest
    Woo, and I might add, hoo! It only went an' bleedin' worked, dinnit?
    Method approved and committed to memory, TY*V*M, Steve.
  19. His heart's in the right place.
    The Older Gentleman, Mar 26, 2011
  20. Vass
    Nige Guest
    For now...
    Nige, Mar 26, 2011
