Honda Goldwing GL 1100 Timing
Discussion in 'Texas Bikers' started by Butch, Aug 14, 2005.
  1. Butch
    Butch Guest
    Can anyone help me figure out the timing problem on my 81 Goldwing
    1100?
    Butch, Aug 14, 2005
  2. Butch
    Silicon Sam Guest
    What leads you to believe you have a timing problem?
    Raymond
    '83 GL1100
    Silicon Sam, Aug 14, 2005
  3. Butch
    Butch Guest
    steve,
    I took this engine apart about a month ago because of a knocking in
    the engine. I put it all back together again, never removing the
    piston or the chain drive. I just checked the bearings and bushings.
    Everything was OK.
    When I tried to start the engine all it would do is misfire or
    backfire.
    It is getting fuel; it is getting spark; but I’m thinking not at the
    right time.
    I would set the left cam mark then the right cam mark according to the
    T1 mark on the crank. But the same back fire. I mean the marks were
    dead on! Then someone told me I could be 180 degrees out. So, I
    started turn the cams 180 out. And now I have NO compression. Now
    What!
    Butch, Aug 14, 2005
  4. How much compression do you have? Is ALL of the timing correct? Valve
    timing? Ignition?
    I hate to be the bearer of bad news but if it was knocking and you didn't
    find or replace anything, it will likely still knock. I think that at this
    point in time you should consider taking it to a mechanic. Where do you
    live? Maybe someone knows a mechanic in your area that can offer some
    advice.
    rj
    R. Pierce Butler, Aug 17, 2005
