Honda CM450C - Transmission clicks when slowly releasing the clutch lever..
Discussion in 'Motorbike Technical Discussion' started by Guest, Aug 14, 2003.
  1. Guest
    Guest Guest
    Newsgroups: uk.rec.motorcycles
    Subject: Re: Honda CM450C - Transmission clicks when slowly releasing the clutch lever..
    Date: Thu, 14 Aug 2003 07:22:05 +0100
    Lines: 16
    someone wrote==> Knackered chain, like I told you elsewhere.
    then i said.. but the sound is comming from inside the engine by the clutch plates right hand side.... not by the chain,,
    i am still at a loss as to what the problem is.
    thanks again,
    david
    Trophy 1200 750SS CB550F2 CB400F ST70 YTC#3
    GAGARPHOF#30 GHPOTHUF#1 IHABWTJ#1 BOTAFOT#60 ANORAK#06 OSOS#1
    BOF#30 WUSS#5 Home page awaiting transfer to Pipex
    **********End Of Post*************
    Guest, Aug 14, 2003
