Honda CD200 Benly... Doesnt Start Well...
Discussion in 'Motorbike Technical Discussion' started by Owen, Feb 15, 2004.
  1. Owen
    Owen Guest
    Hi, I have an '82 CD200 Benly. It has, until about a year ago, always
    been reliable and started well. However, recently, although it hasnt
    been used very much, every time its started it doesnt start well. It
    smokes alot more than it did, oil is coming out of the left hand
    exhaust where the downpipe joins the silencer, and the left hand
    cylinder doesnt enjoy firing. Also, sometimes it barely starts at all.
    Ive cleaned the carburettor (jets etc.), set timing, set valves, air
    filter is fine, has a nice fat spark, and the fuel flows well.
    Any ideas?
    Cheers, Owen.
    Owen, Feb 15, 2004
  2. Owen
    JS9 Guest
    Smoking? Not firing on one side? Check compression and get ready to
    Or, just add some solvent (such as Sea Foam) to the oil to unstick the gummy
    rings and restore compression.
    JS9, Feb 16, 2004
  3. Owen
    Owen Guest
    Damn. I just went and did a compression check on each cylinder, and
    the left hand was reading 50ish, the left hand about 70ish. What next?
    I realise these are quite low readings...
    Thanks, Owen.
    Owen, Feb 16, 2004
  4. Owen
    Owen Guest
    Err... I forgot to add that the oil is creamy... suggesting water
    getting in... Could this actually be petrol?
    Owen, Feb 17, 2004
  5. Owen
    John Johnson Guest
    [low compression readings and possible interpretations snipped]
    Does it smell like petrol? That's usually the easiest way to tell if
    you've got gas in the oil.
    John Johnson, Feb 17, 2004
  6. Owen
    Owen Guest
    Yes, it has been outside; albeit under cover, however water could
    easily get in I'm sure.
    I went to start it today and it started first kick! It still smokes a
    bit too much out of the left hand cylinder, however the right side is
    fine. It seemed to improve slightly as I left it running (approx. 10
    minutes) but when I piled on the revvs it went a bit smokey still.
    I will endeavour to do a complete compression check.
    I have set the valve clearances, and also the valve timing.
    Thanks, Owen.
    Owen, Feb 17, 2004
  7. Owen
    Steve H Guest
    Its a little off base but have you checked the carbs float bowls? I know the
    engine layout is (very!) different but I've had loads of problems with my
    BMW R80/7. It lives outside undercover and if it hasn't been started for a
    while it used to be a complete pig to start, firing on only one cylinder,
    loads of smoke then chiming in with the second cylinder. The carbs are out
    in the breeze, although under the cover and I discovered that water was
    getting into the float bowl. As the petrol floats on the water, it was
    sucking water through the one carb, hence the smoke. I pull the bowls off
    (at least an easy job!) everytime before starting after it has been standing
    for a while now.
    Steve H
    Steve H, Feb 17, 2004
