can anyone tell me how much oil a `92 cbr 400 rr take when servicing? cheers simonb
The capacity is almost invariably embossed on the engine/gearbox casting/cover in the area of the oil filler. Failing that, but 4 litres because it *will* be less than that, chuck half of that in, then top up slowly to the indicated line on the sightglass or dipstick. How difficult can it be?
Indeed, Brother Snot Gobbler. I didn't wish to be so obnoxious so soon, you see. It is a task fraught with difficulties and pitfalls, dealing with the semi-sentient - as is changing bike oil, apparently.
I was expecting a post from the OP along the lines of:: " so if I've put in 7 litres of hypoid 90, does that explain why the exhaust smoke is black and the clutch slip in all gears. Keep up the good work, brother. Amen.
'92...That's an "N" spec, isn't it? L&N models: 3.2l if not changing the filter, 3.4l if also changing the filter, 3.8 if it's bone dry. It should, as Pip sez, say on the clutch cover, however, it's in sticker form and in Japanese if it's still on there. If I'm wrong about the year and it's an "R", then the numbers change to 3.0l, 3.2l and 3.8l accordingly. HTH. -- | Wik -UKRMHRC#10- 2003 R1150GSA -DC#1 -'FOT#0 'FOF #39 - BOD#12 BOB#12 |# You don't believe me | "Experience is the worst teacher. |That the scenery | It always gives the test first |Could be a cold-blooded killer. | and the instruction afterward." ***** human response from wik at blueyonder dot co dot uk *****
