Honda CBR 1000 -87 noise
Discussion in 'Motorbike Technical Discussion' started by Vesku, Sep 9, 2003.
  1. Vesku
    Vesku Guest
    kind of "rattling", "knocking" noise only when idling, no noise with >2000
    rpm. I,ve heard that timing chain tensiner could cause noise, opened valve
    cover, now when pressing timing chain it does not feel "slacky" at all.
    Hard to believe that the tensioner could cause the problem.
    Is there any other part that could cause similar noise ? Something in
    starter/alternator drive ? Clutch ?
    br Vesku
    Vesku, Sep 9, 2003
  2. Clutch rattle, and ignore it.
    The Older Gentleman, Sep 9, 2003
  3. Vesku
    Hank Guest
    lucky for him it's a Honda, not a Suzuki........................
    Hank, Sep 10, 2003
  4. Vesku
    Hank Guest
    AFAIK the CC tensioner problem was only on the CBR600, not the completely
    different CBR1000.
    Hank, Sep 10, 2003
  5. Vesku
    Devlin Guest
    If it's a subtle sound I would agree with TOG and say it's clutch
    rattle. Have the same thing on my 88 ZX10. Don't ignore it though, if
    you tune your bike and balance your carbs it'll run smoother and the
    knock will be minimized, maybe even reduced so much you won't hear it.
    Did a full tune-up on my bike and you can barely hear it now.
    Devlin, Sep 10, 2003
  6. Vesku
    Geribaldy Guest
    My brothers CBR1000 used to do it.It improved a lot after I balances his carbs, but it still rattles
    a bit.
    Geribaldy, Sep 10, 2003
  7. Vesku
    motownmoto Guest
    Vesku ......
    Mileage, give us the mileage........
    moto
    '95 750 Nighthawk (big red)
    '95 Helix (little red)
    '93 Ninja (up 'n runnin')
    motownmoto, Sep 11, 2003
  8. Vesku
    Vesku Guest
    Mileage is 105000 km / about 70k miles
    In fact I have already opened valve cover to check timing gear and checked
    clutch plates, everything seem fine. I contacted previous owner, timing
    chain and tensioner have been replaced about 10-15 k miles ago.
    I put everything back and tried running the engine tonight, tried touching
    the engine and accessories, it is posssible to "feel the rattling/knocking"
    when touching alternator cover with finger.
    How to examine alternator/starter ? Haynes seems a bit confusing. It seems
    that if alternator drivechain or tensioner has to be replaced, the engine
    has to be taken out of frame and opened completely, But what is possible to
    examine without major operation, to check if bearing fault or something
    loose inside alternator/starter et.c ?
    br Vesku
    Vesku, Sep 12, 2003
