Honda Bros engine donors?
Discussion in 'UK Motorcycles' started by Geo, Dec 19, 2007.
  1. Geo
    Geo Guest
    There's a 400cc Bros on sale for spares around here, essentially the entire
    bike with a damaged engine which apparently is not included. I always liked
    the Bros and despite being a hopeless "n00b", I like the idea of trying a
    half-arsed project (that I can afford and I don't necessarily have to finish
    within the next 10 years) . This is not particularly serious, but if you're
    bored and possess knowledge on the subject, here's your chance to show it
    off. Your knowledge that is, not your boredom.
    AFAIK the Bros 400 frame is the same as the 650 bike so no problems there,
    but what I'd like to know is which other Hondas could donate an engine. If
    I'm not mistaken variants of the same engine power the Transalp 600/650,
    Revere600/NTV650/Deauville650 and Africa Twin 650/750 so any of those should
    be an easy fit (minus the potential shaft or possible gearing issues). Does
    anyone know if there are any differences that one should be aware of? I read
    for instance that the Transalp 650 engine lacks the upper rear mounting
    point and has at least a couple more differences that could be an issue.
    Other than that, I've been wondering whether the new 4-valve version is
    similar enough to the old engine. Could someone just use the
    heads/injection/whatnot and bolt them on an old engine (doubt it)? Would the
    newer engine be a straightforward fit in an old frame? That'd be too
    expensive anyhow, but I'm curious.
    Any wisdom regarding Bros (Broses?) and suggestions very much appreciated.
    "Don't be daft" does not count as a suggestion.
    Geo
    Geo, Dec 19, 2007
