Honda 450 Nighthawk (1985)
Discussion in 'Motorbike Technical Discussion' started by Ivan Vegvary, Apr 15, 2007.
  1. Ivan Vegvary
    Ivan Vegvary Guest
    Long story short. Bought the bike 5 years ago, rode it for a total of 2-3
    hours (5-6 rides) and its been parked for the last 4 years. With new
    battery, fully charged, the starter will not turn the engine. Maybe its
    frozen.
    Should I be able to turn the engine by turning the rear wheel. This bike
    does not have a kick starter. I'll take out the spark plugs to make it a
    little easier and put it in 4th gear.
    Any other ideas on how to un-freeze this engine would be appreciated.
    Thanks,
    Ivan Vegvary
  2. Poor some releasing oil down the spark plug holes and wait a few days,
    then try again.
    The Older Gentleman, Apr 15, 2007
  3. When you say "the starter will not turn the engine," do you mean that
    nothing at all occurs? Have you tested to see if voltage is getting to
    the starter? Does the starter sound like it's trying but is being held
    back? When you hit the starter button, does the headlight dim? More
    info, please.
    mad scientist, Apr 15, 2007
  4. Ivan Vegvary
    Bruce Farley Guest
    Remove the flywheel cover (left side) and see if you can turn the engine
    over by rotating the crankshaft. If it is solid the rings are probably
    rusted. Try with the spark plugs removed.
    Bruce Farley, Apr 15, 2007
  5. Ivan Vegvary
    Albrecht Guest
    It's not clear from your description whether the starter solenoid is
    clicking or if the starter is groaning and trying unsuccessfully to
    crank the engine.
    If you're not even hearing the solenoid clicking, the first thing to
    check is whether the kill switch is in the RUN position, and do just
    assume that a switch on a motorcycle that old is working correctly
    just because it's set to the position where it's supposed to work.
    Sometimes you have to operate a switch several times through all of
    its positions to knock some of the corrosion off the contacts.
    Another thing to be aware of when the solenoid won't click and nothing
    electrical on the motorcycle works: Honda makes a practice of
    concealing a main fuse under the cover of the starter solenoid. In
    your case, it looks like a 20 amp blade type fuse.
    If the pistons and rings really have rusted to the cylinder walls,
    some penetrating oil is in order. After an engine is unfrozen, an oil
    change is in order to get the loose rust out.
    Albrecht, Apr 15, 2007
  6. Ivan Vegvary
    Ivan Vegvary Guest
    Thanks for all the replies, group!!! All turned out OK. Like I said, it's
    been about 4 years since this bike ran. When I went to pull the sparkplugs,
    my plug socket seemed real loose. Tried different sockets, nothing worked.
    Finally realized that the plugs themselves were loose. Evidently I did top
    off the cylinders (4 years ago) with oil and left the plugs loose.
    Anyway, the engine turns over fine, so I obviously have an electrical issue
    with the starter or starter circuit.
    Thanks again,
    Ivan Vegvary
    Ivan Vegvary, Apr 16, 2007
  7. Ivan Vegvary
    Albrecht Guest
    OK, so cycle your ignition switch and the kill switch through all
    positions several times to knock off the corrosion. If nothing
    happens, try
    jumpering across the appropriate contacts of the switches.
    You'll need to study your wiring diagram carefully before bypassing
    the switches. Newbies get confused by the color coding on the wire
    harness typically not matching the color code on vendor components, so
    you have to pay attention to the connector diagrams.
    Check all electrical connections, such as the battery cables and the
    plastic connectors in the wire harness. Check all fuses in the fuse
    panel and check the hidden main fuse on the starter solenoid.
    Yes, you can stick a screwdriver across the two large posts of a
    starter solenoid. Electrical arcing may damage the posts as you prove
    that the starter works.
    Some riders have said that they did everything they could think of to
    troubleshoot their starter problem, and finally discovered that the
    steel starter case just wasn't making good contact to the corroded
    aluminum engine crankcase. The engine itself is used to complete the
    electrical circuit back to the battery, via a "grounding" strap and
    the battery negative cable.
    Albrecht, Apr 16, 2007
  8. Ivan Vegvary
    Wudsracer Guest
    In addition to the above, check your connection from the grounding
    cable to the engine or frame. This is a very important and often
    overlooked source of problems in starting and charging systems on m/c
    & atvs.
    If the cable goes to the frame, then your motor mounts are providing
    that crucial grounding link, and must be looked at as a potential
    source of difficulties (in charging and in getting full electrical
    power to the starter.
    Wudsracer/Jim Cook
    Smackover Racing
    '06 Gas Gas DE300
    '82 Husqvarna XC250
    Team LAGNAF
    Wudsracer, Apr 16, 2007
  9. Ivan Vegvary
    Ivan Vegvary Guest
    Albrecht & Wudsracer,
    Thanks for the sage advise. Yes, I wiggled the key, wiggled the kill
    button, wiggled the starter button AND, found the sweet spot and the engine
    turns over fine. I do have some contact cleaner and will try to clean all
    those connections.
    Question!! I can't for the life of me find the headlight switch. I have a
    High/Low beam switch on the left grip but no on/off button. Is the
    headlight supposed to be always on? Controlled by the ignition key?
    Advice appreciated.
    Ivan Vegvary
    Ivan Vegvary, Apr 17, 2007
  10. Ivan Vegvary
    Ivan Vegvary Guest
    Thanks Mark!!! You gave me all the answers plus the cautionary note.
    Ivan Vegvary
  11. You know, the ignition switch on my 400 Four is occasionally dicky. It's
    just the lighting circuit - to get the tail light to light, I have to
    turn the switch to the parking light detent and then back a click. I've
    been meaning to take the swtch apart and clean it for years, but I
    hardly ever ride the 400 at night, and so...
    ....this weekend I'll do it. Promise.
    The Older Gentleman, Apr 17, 2007
