honda 1982 cm450 voltage regulator output
Discussion in 'Motorbike Technical Discussion' started by steve, Jan 27, 2008.
  1. steve
    steve Guest
    What should output on this be?I'm getting 14 volts.Will this blow out the
    headlight?Thanks
    steve, Jan 27, 2008
  2. steve
    . Guest
    No, it will not blow the headlight out. A 12 volt battery will charge
    up to about 14.5 volts,
    and then after it sits for half an hour, the voltage will drop back to
    about 12.2 to 12.8 volts, depending on whether it's a flooded cell
    battery or a maintenance free type.
    Charging a flooded cell lead acid battery at more than 14.5 volts
    causes the plates to shed their lead and it falls to the bottom of the
    case, possibly shorting the plates.
    ., Jan 28, 2008
  3. steve
    MadDogR75 Guest
    14 volts is fine.
    A fully charged lead acid battery should give 12.8-13.2 Volts.
    14 -16 is right for charging and won't harm the lights.
    MadDogR75, Feb 5, 2008
  4. 16 sounds a mite high, depending on the battery I guess.
    As others have suggested 14.5 is probably about the
    most I'd feel comfortable with on a lead-acid battery.
    Rob Kleinschmidt, Feb 5, 2008
  5. steve
    . Guest
    Maintenance free batteries use a slightly different electrochemistry,
    so voltage regulators on bikes that came with maintenance free
    batteries will stop charging at 15.5 to 16.0 volts.
    But that much voltage is not healthy for older style flooded cell lead
    acid batteries, it will cause the plates to shed lead particles.
    ., Feb 6, 2008
  6. steve
    Bharmoncm450e
    Jun 24, 2022
    1
    0
    Hey y’all, I have a 1982 cm450e that I’m building..
    I think I blew the voltage regulator last night and I’m not sure why, I have a 12 volt battery.. I don’t have the best knowledge when it comes to wiring, any advice? Thanks!
    Bharmoncm450e, Jun 24, 2022
