Hole size for bolt
Discussion in 'UK Motorcycles' started by Bill, Oct 27, 2003.
  1. Bill
    Bill Guest
    What size hole does a 10mm headed bolt need to go through, is a normal 10 mm
    headed bolt M6 or M8?
    I don't have access at the moment to any to measure.
    Cheers
    Bill
    Bill, Oct 27, 2003
  2. Bill
    Shank size Thread Spanner
    Pitch Size
    M6 (6mm) 1.00mm 10mm
    M8 (8mm) 1.25mm 13mm (12mm on some Japanese bolts)
    M10 (10mm) 1.50mm 17mm
    M12 (12mm) 1.75mm 19mm
    Tapping Drill Size = Screw Diameter - Thread Pitch (rule of thumb).
    For the shank hole, I'd use an oversize drill bit about 0.5 mm
    sweller, Oct 27, 2003
  3. Bill
    Slider Guest
    The clue is in the '6' and '8'. M6 = 6mm, can you guess what M10 is? ;-)
    Slider, Oct 27, 2003
  4. Bill
    Bill Guest
    Brilliant, cheers
    Bill
    Bill, Oct 27, 2003
  5. Bill
    Slider Guest
    D'oh; ignore that. Fools rush in etc...
  6. Bill
    mb Guest
    Bolts with a 10mm head are *normally* M6.
    mb, Oct 27, 2003
