Hmm... that noise isn't normal...
Discussion in 'UK Motorcycles' started by Stevie, Oct 23, 2006.
  1. Stevie
    Stevie Guest
    Progress update!
    I've managed to remove the balls and the inner race. However the outer race
    is proving very resistant. I've been cutting for well over an hour now and
    I'm only 80% through one cut, and I've worn out all of the 8 mini grinding
    stones that I had for my Dremel-type mini drill. Is this to be expected? Or
    am I using the wrong tools?
    Some of the grinding stones vanished in a minute, whereas a couple lasted
    for over 10 mins. Is there a difference in quality in these things? They all
    came from Maplin's.
    I'd like to use the thin 3cm diameter cutting wheel in the Dremel but then I
    can't get in at the right angle :-(
    Help!
    Stevie, Oct 28, 2006
    #61
  2. Stevie
    If you're using 'stone' type grinding bits then they come in different
    grades and the way to tell the difference is the colour. Pink ones are
    slightly harder than white ones so if you're going to buy more then
    they're the ones to go for.
    If you can get a carbide bit (a steel one that looks like it has
    loads of tiny little cutting teeth on it) then that's the way to go.
    It'll rip through the bearing outer in a couple of minutes. These are
    the ones that you have to be really careful with because they'll send
    loads of tiny slivers of steel flying everywhere.
    Andy Bonwick, Oct 29, 2006
    #62
  3. Stevie
    Scraggy Guest
    Not that I have a clue, but I have just read, elsewhere, that a line of weld
    on the outer race inner surface[1] is the way forward. It shrinks on cooling
    and the race will pop out. Allegedly. Do you think that would work Andy?
    Just a thought.
    [1] It was related to head bearing when I read it but ...
    Scraggy, Oct 29, 2006
    #63
  4. Stevie
    On Sun, 29 Oct 2006 11:54:56 -0000, "Scraggy"
    snip>
    It works but the small matter of where you put the return lead would
    concern me. I don't know enough about welding to advise anyone on it,
    I can stick bits of metal together and I can build things up with weld
    but it's not really something I do.
    #64
  5. Stevie
    Stevie Guest
    Yes, its the stone type I've been using. Some are pink, some are blue. The
    best one was definately pink.
    Are these the carbide ones you mean? (top right)
    http://www.maplin.co.uk/images/full/L48BK.jpg
    However I wont be able to get them in at the right angle to be ueful.
    Or these look good quality, but they're white:
    http://www.lawson-his.co.uk/scripts/products.php?cat=Dremel Silicone Carbide Grinding Stones
    "Use as you would use an aluminum oxide stone, but these stones are designed
    to work well on hard materials such as porcelain and gemstones,stone, glass,
    ceramics and hardened metals."
    Stevie, Oct 29, 2006
    #65
  6. Stevie
    Stevie Guest
    Hmm... I like the idea... but I dont think this will help. I still need to
    lift the bearing off the piece of metal that locates in its groove, so I
    need to put the big cuts in the outer race anyway. How deep is this groove?
    Anyone know where I buy 'bearing fix' glue from? In Nottingham or online?
    #66
  7. Stevie
    They'd work well but the type I meant are these ones:
    http://www.chronos.ltd.uk/acatalog/...g_Wheels___Wheel_Dressers_92.html&CatalogBody
    Scroll down until you see the set of 12 solid carbides. I've only used
    this link because of the photo btw, you'd have to search around to
    find ones that fit a dremel unless you get a 6mm collett with the
    dremel.
    #67
  8. Stevie
    Stevie Guest
    You'll have to remove the balls and split each race in two or you'll
    <snip>
    I've got the old bearing out. Hurrah!
    The only grinding stone which lasted was a pink one and after the glue which
    holds it to the shaft melted, I superglued it back on and it managed to last
    the whole second cut of the outer race. Then with 10 minutes of levering and
    head scratching I managed to get the two halves out, past the retaining
    ring.
    Questions now:
    1) how do I get the retaining ring out? It doesn't want to come out easily
    and I dont fancy just grinding it all away (but I could)
    2) As I dont need the official Suzuki bearing with a groove in it, where
    could I get a generic one from (assuming at a fraction of the cost - a
    mechanic guessed the Suzuki one would be around £60!). And where do I get
    'bearing fix' glue?
    3) what does the retaining ring do? (part 39 on here
    http://images.powersportsnetwork.com/fiche/images/Suzuki/1988/Motorcycles/2119_17.gif )
    I cant see that it actually needs to do any retaining as the front sprocket
    holds part 46 tight up against the bearing, so the bearing cant creep
    anywhere.
    Ta for your help so far. I love a good bodge... :)
    Steve
    #68
  9. Stevie
    snip>
    If you grind into the centre of it you should be able to 'fold' it and
    then remove it.
    Measure the casing bore, the shaft diameter, and the width required.
    These three sizes will give the bearing size. If you've been lucky
    removing the bits and haven't thrown them away you might see some
    numbers on the edge of the outer race. Go to your nearest bearing
    stockist, give him the sizes, tell him the application and away you
    go.
    Bearing fix is just a description of what you need. Loctite 638
    retainer will do the job but make sure the casing is spotlessly clean
    and only use a small amount. Wipe away any surplus and don't get it in
    the bearing or it'll lock solid.
    You may not need to use anything to lock the bearing in place. Check
    if the bearing is a decent fit before you glue it in place.
    The ring does a job in that it positions the bearing in the correct
    place. Measure the old outer against the position of the ring and see
    if the bearing goes tight against the shoulder of the shaft. It looks
    as if it does but you need to check. If it doesn't go hard against the
    shoulder then you'll need to use the Loctite to hold the bearing in
    the right place. Loctite cures quickly so you'll only get one chance
    to position the bearing correctly if you have to do this.
    No probs.
    #69
  10. Stevie
    It's all quite encouraging so far really!
    Hog, Oct 29, 2006
    #70
  11. Stevie
    I'm out of the country from Thursday so it's over to Nigel for
    completion...
    Andy Bonwick, Oct 30, 2006
    #71
  12. Stevie
    Taking herself on a well earned holiday to balmy golden shores one would
    hope
    Hog, Oct 30, 2006
    #72
  13. Stevie
    We're off to Sharm El Sheikh for a week if that's what you meant.
    #73
  14. Stevie
    Andy Bonwick says...
    I didn't think any holiday could compensate for trying to sleep with her
    mother.
    Lozzo
    GSF600SW (broked)
    'I do not object to people looking at their watches when I am speaking.
    But I strongly object when they start shaking them to make certain they
    are still going.' William Norman Birkett, 1st Baron Birkett, Oct 1960.
    Lozzo, Oct 30, 2006
    #74
  15. Stevie
    It's a mistake (1) anyone could make
    (1) or not
    Hog, Oct 30, 2006
    #75
  16. Stevie
    Aye. Nice one.
    Beer Tues or Wed BTW
    Hog, Oct 30, 2006
    #76
  17. Stevie
    Hog says...
    I can't comment, I've never met Adie's mum.
    Lozzo
    GSF600SW (broked)
    Lozzo, Oct 30, 2006
    #77
  18. Stevie
    Kendal Tuesday, Gatwick Wednesday for the morning flight so you'll not
    be able to take the piss.
    #78
