I know valve lash must be checked/adjusted after top-end rebuilds. My question is: does anything about these valve lash numbers seem funny to you experienced rebuilders? (please see numbers below) Quick background: My first time doing a top-end rebuild on a 1998 zx7r motor with ~27k miles. The rebuild consisted of new ferrea valves with stock valve head thickness. I had an experienced acquiantance of mine remove the old valves and oil seals, grind the seats to factory specs, lap the valves, and install the new valves and oil seals. I did all the rest of the labor. Factory valve clearence spec: Exhaust: 0.22 - 0.31mm Intake: 0.17 - 0.25mm Valve clearances BEFORE rebuild: EXHAUST: ranged from .20-.28mm INTAKE: ranged from .18-.20mm The existing shims ranged from 2.85-3.05mm. Valve clearences AFTER rebuild: Exhaust: ranged from .457-.559mm!! Intake: ranged from .610-.635mm!! where did this increase of ~0.40mm (0.017") come from? So for whatever reason the valves are either sitting farther away from their seats or the stem lengths are shorter. First thing I thought was maybe the new valve heads or stems are actually different from stock specs. I removed a new intake valve and measured the valve head thickness and total valve length including stem best i could with dial calipers and they are the same as the stock valves removed. Next I thought maybe my friend ground the seats down TOO FAR. Seems possible to me. But that would have the opposite effect. If the new valves sink deeper into the engine head, the stem rises higher towards the cam lobes and the clearence would get tighther. Correct? So it must be something else... So i went ahead and got all new shims in range of 3.05-3.4mm. After reassembly, the new numbers are: Exhaust: largest clearance .36mm Intake: largest clearance .43mm!! Tallest shim I can buy is 3.5mm? That would bring me closer to the high side of the factory spec range...but I have to check on that... It took me a long time to figure out how to properly check the valve clearances but I am certain I am reading the numbers right. Once thing I realized is how important it is to pre-bend the tips of the Autozone feeler gauges I am using, so that they are NOT trying to bend as you insert them between the shim bucket and the cam lobes. So...does anyone have any insight into any of this? I hope that someone does... Thanks!
