High Octane Fuel
Discussion in 'UK Motorcycles' started by toad, Jul 18, 2007.
  1. toad
    toad Guest
    How does High Octane Fuel improve engine performance?
    I assumed it slows the ignition so you could compress the fuel more
    and change the timing. So High Octane Fuel on a vehicle with no Anti
    Knock Sensor and the timing set up for 95 RON fuel would get no
    benefit. Is that right?
    toad, Jul 18, 2007
  2. toad
    Yes. Unless an engine is designed for high-octane, delayed ignition,
    whether it be fixed or electronically controlled, using the more
    expensive stuff will have no benefit.
    _______
    \`\ | /`/ DS#8
    Ace, Jul 18, 2007
  3. toad
    OH- Guest
    Yes.
    OH-, Jul 18, 2007
  4. In a nutshell, yes.
    Of course, you do get the benefit if your engine has a higher CR and you
    can make extra power from that fuel - these days with the electrickery
    gizmo to make it so. The same EG will enable the engine to run on crap
    petrol, so it's a win-win.
    GS850x2 XS650 SE6a
    river cleaned out in a day.
    Grimly Curmudgeon, Jul 18, 2007
