High level rear light on CanBUS bike?
Discussion in 'UK Motorcycles' started by T i m, Jan 10, 2008.
  1. T i m
    T i m Guest
    Hi All,
    Does anyone know of a gadget that would allow the connection of a high
    level brake light on one of the modern bikes (a BM in this case) that
    use a single 21W lamp for tail / stop light please?
    It's for a mate and he just wants the lamp (or strip of lamps in this
    case, mounted in the top box) to come on in synch with the std brake
    light.
    All the best ..
    T i m
    T i m, Jan 10, 2008
  2. T i m
    Try this:
    http://bmwsporttouring.com/ubbthreads/showflat.php/Cat/0/Number/966215/Main/965780
    I haven't been paying much attention to CANBus before now, but Jesus,
    CAN'TBus or what? It's like Vista for bikes.
    platypus, Jan 10, 2008
  3. T i m
    Well, I just had a quick google and received the distinct impression that
    the implementation, on BMW bikes at least, was a pain in the arse. Examples
    of CANBus getting its knickers in a twist over such things as such battery
    chargers, spotlights, high-power headlight bulbs and so forth.
  4. T i m
    Adrian Guest
    That doesn't differ from multiplexed car wiring one bit...
    Adrian, Jan 10, 2008
  5. T i m
    T i m Guest
    Thanks for that.
    I can see how some of it could be a good idea, especially as these
    machines have more and more options / functions. Bulb failure
    indicators being one that could be considered a safety feature for
    example?
    <weg> Would I buy something that complicated ('complicated' being not
    having access to the tools needed to diagnose / configure this stuff)
    not till I had to I wouldn't.
    But then I guess it's just progress. I remember fitting the Luminition
    optical ignition points replacement unit to the kitcar when we built
    it 18 years ago and haven't had need to touch it since ...
    All the best ..
    T i m
    T i m, Jan 10, 2008
  6. T i m
    Not just cars. I've seen it used in industrial machinery, too.
    Pip Luscher, Jan 10, 2008
  7. T i m
    I don't recall plain-Jane CANbus causing particular problems, though I
    wasn't directly involved. It's possible that extra security stuff for
    automotive use - particularly bikes but remember that Audi bug - has
    buggered it up.
  8. T i m
    Mark Olson Guest
    The CANbus itself and indeed the entire system works pretty well. The
    problem is that folks expect to be able to replace bulbs with those of
    different wattages, and are being caught out when the smart switch sees
    a different load than it expects, and the controller shuts down the
    circuit or turns on a warning light. If I wanted to add electrical
    gubbins to a CANbus bike, I would attach a fuse panel directly to
    the battery and bypass the CANbus system.
    Mark Olson, Jan 10, 2008
  9. T i m
    Aah, of course: one power circuit = one fuse, unless you have fuses
    scattered all over the place.
  10. That in itself can throw up problems as the system detects an
    unidentified power drain ,
    steve robinson, Jan 10, 2008
  11. T i m
    T i m Guest
    Which is what my mate intends to do for all the std auxiliary
    requirements but this brake_light_only trigger is a bit more
    complicated.
    I guess we don't want to load the bus by much or it might cause a
    false fault trigger so that means some form of high input impedance
    device driving a suitable output device (relay?). Nor do we want to
    inadvertently 'earth' something so a floating / isolated input might
    be best.
    What we don't know is what's going on, what makes this 21W lamp go
    from the equivalent light output of a 5W for a tail light to the full
    21W for a brake light?
    I'm guessing it's a 'simple' voltage step, either outputted directly
    from the controller module or by the 'shorting' of a load resister
    (simple but less efficient) but it's not impossible that it could use
    some form of PWM?
    I though this buss stuff was similar to USB .. a host 'talking' to
    'devices' and those (coded) devices (typically micro relays in this
    role) doing what they were told via data on the bus?
    The actual energy being fed to the lamp should be fairly easy to
    'detect' but we just need to know how to make a suitable circuit to
    match (anyone know please)?
    All the best ..
    T i m
    T i m, Jan 10, 2008
  12. Using the patented Mavis Beacon "Hunt&Peck" Technique, Mark Olson
    A rather easier way might be to flog the piece of pointlessly
    over-complicated shit and buy a bike.
    Honda GL1000K2 (Fallen apart) Suzuki TS250 "The Africa Single"
    Norton 850 Commando Kawasaki GTR1400
    Wicked Uncle Nigel, Jan 10, 2008
  13. T i m
    T i m Guest
    I'll go with that .. ;-)
    Ok ..
    Ok ..
    They are nearly my exact words to my mate when he first asked last
    night! ;-)
    Yep. Would it just need any low pass > comparator decoupling to be
    fairly 'tight' so-as not to hang on to the signal once it drops back
    to tail light?
    It does indeed, thanks Mark.
    All the best ..
    T i m
    T i m, Jan 10, 2008
  14. T i m
    T i m Guest
    I'm not sure that's a solution in this case, partly as he hasn't
    bought the thing yet and partly because he *needs* something like this
    (I think his current ride is a K1200LT) for the fairly enormous miles
    he put's on the things each year.
    All the best ..
    T i m
    T i m, Jan 10, 2008
  15. Using the patented Mavis Beacon "Hunt&Peck" Technique, T i m
    There's still time! Thank ged!
    See comment above.
  16. T i m
    T i m Guest
    T i m, Jan 10, 2008
  17. T i m
    T i m Guest
    I've just received an eMail from my mate with an attached eMail from
    someone who knows and it's exactly as you (and I) speculated and PWM
    It also appears it's two single filament lamps (presumably in
    parallel, this is the K1GT we are talking about specifically here).
    So, what is a popular robust opto isolator these days Mark .. ;-)
    All the best ..
    T i m
    T i m, Jan 10, 2008
  18. T i m
    T i m Guest
    Ok ..
    Understood.
    Thanks again Mark and all the best ..
    T i m
    T i m, Jan 11, 2008
  19. T i m
    Mark Olson Guest
    Got me, guv. Honestly I can't see any benefit at all to the user
    in using CAN bus technology other than perhaps it allows some
    improved diagnostics, such as indicating a burnt out taillamp.
    On a motorcycle it's pretty pointless, as you say. Leave it to
    BMW, lately they don't seem to be able to resist adding needless
    complexity.
    You might well change your tune about KI-PASS and all the related
    nonsense if it goes tits up and leaves you stranded. There seems
    to be a fair amount of teething pain associated with all the new
    tech toys on the GTR1400.
    Mark Olson, Jan 11, 2008
  20. Using the patented Mavis Beacon "Hunt&Peck" Technique, Mark Olson
    oh, doubtless. I'll whinge like a mofo when it fails.
    Wicked Uncle Nigel, Jan 11, 2008
