High idle - intermitently
Discussion in 'Australian Motorcycles' started by James Murray, Sep 14, 2004.
  1. James Murray
    James Murray Guest
    Hi Guys,
    I have a problem that has developed recently (last two days) that I
    would like your help with. The bike is a 1996 RGV 2stroke.
    When I stop at a set of traffic lights, the revs will come down to
    4000rpm and not to the usuall 1600rpm. If I blip the throttle, it will
    usually return to 4000, but sometimes down to the normal 1600.
    What is interesting, is that when it rests/idles at 4000rpm - if I
    move the throttle only slightly, it starts to rev up (ie, If it were a
    cable issue, I would expect there to be some slack in the cable before
    it starts reving up from 4000rpm, but it doesnt).
    If I drop it into gear, slowly release the clutch until friction
    point, the revs will drop down and then idle at 1600rpm like it should
    - sometimes returning to 4000, but usually not when I pull the clutch
    back in - so it can be forced to drop its idle back down to normal -
    dont understand why?
    I have checked the choke, and it is operating corerectly and the choke
    is not on when this behaviour is present.
    Sometimes, the idle is just fine, as if nothing is the miss.
    So, what are the possibilities?
    I guess it could be;
    *a sticky throttle cable
    *a sticky throttle lever on the carb
    *something amiss with the idle screw - but not likely, since it
    returns to normal sometimes
    *a crack or hole somewhere in the fuel lines allowing more air in
    somewhere (help on this one please)
    *loose carb boot, allowing (extra) air to be sucked into one cylinder?
    What I have also found is that when I start it first thing in the
    morning, with no choke as usual, the revs seem lower than normal (like
    1400) where usually it revs upto around 4000 for around a minute than
    drops down to 1600 as normal.
    Is it possible that this is as a result of a foulling plug?
    I have had the tank off a few times, to do things like clean the
    powervalves, balance the carbs and removed the airbox (for access to
    he carbs), so it is possible that I have bumped something or worked
    something loose.
    What i am afraid of, is causing the bike to run lean and doing some
    engine damage.
    The bike seems to run sweet at anything other than idle.
    Cheers, James
    Kurrajong Australia.
  2. In aus.motorcycles on 13 Sep 2004 21:45:11 -0700
    Vague 2 stroke memories say "air leak". Meaning check carby rubbers and
    exhaust pipes and gaskets.
    Zebee
    Zebee Johnstone, Sep 14, 2004
  3. James Murray
    Johnnie5 Guest
    yep what she says
    look for air leaks
    Johnnie5, Sep 14, 2004
  4. James Murray
    Fwoar Guest
    crank seals
    Fwoar, Sep 14, 2004
  5. Yep. Airleaks it is.
    Most likely culprit are the rubber intake manifolds.
    Had you done anything to the bike just before the problem first became
    apparent?
    James Mayfield, Sep 14, 2004
  6. Yep, split the cases.
    Pisshead Pete, Sep 14, 2004
  7. Zebee said....
    Yep, and a great way to add that extra hole to the piston......
    Martin Taylor, Sep 15, 2004
  8. James Murray
    Stoneshop Guest
    [high idle revs]
    Most likely cause, IME.
    With the engine idling (doesn't have to be at high idle at that moment), spray
    some WD-40 or similar on the boot. If the revs change there's an air leak.
    // Rik Steenwinkel '85 R80ST Skippy bike
    // Enschede, Netherlands '91 R100GS/PD The Great Unwashed
    // N 52.2158 E 6.88589 '90 K75C Kommutabike
    // "Far away is only far away '81 MZ TS250/1+LSW Badkuip
    // if you don't go there" '79 Honda XL250S TBD
    Stoneshop, Sep 16, 2004
