High Idle, Choke Stuck?
Discussion in 'Motorbike Technical Discussion' started by jois.de.vivre, Aug 22, 2006.
  1. Hi I recently got a 2001 Katana 750 and I'm having some trouble with
    the idle. When I first got it, it ran fine, but the battery soon died
    (possibly because it was low to begin with). I charged the battery but
    when I tried to run it again it seemed like it was struggling. It
    would idle between 1000 and 1500 rpm but would jerk forward as if it
    was about to stall when I would ride slowly in first gear. I thought
    it was because of the cold so I opened the choke when I started it
    next, and it the jerking seemed to go away. But when I tried to close
    the choke, nothing happened. The choke lever seems fine and moves
    without a problem, but the engine is now constantly idling at 4500 rpm!
    Is it possible that somehow the choke got "stuck" open? I don't know
    that the battery dying has anything to do with the choke being stuck,
    but everything was running fine until that happened.
    Thanks,
    Prashant
  2. jois.de.vivre
    B-12 Guest
    You have the typical dirty carburetor problems that mystify those new
    owners who are not acquainted with the care and feeding of constant
    vacuum carburetors.
    Constant vacuum carburetors work very well when they are clean inside,
    but the tiny holes in the jets and internal passages get plugged up
    easily.
    The gasoline in the float bowls evaporates when the motorcycle sits
    unridden for a few months. When that happens, the gasoline turns into
    gum and varnish, blocking the idle jets and passages.
    Maybe the rider first notices that the engine idles too slow and finds
    the master idle knob under the carburetors and adjusts it so the
    engine idles at the right speed, but he doesn't notice that he now has
    to play with the throttle grip to get the engine to start.
    Then he lets the motorbike sit unridden some more and more gasoline
    evaporates
    and plugs the jets even more. When the idle jets and idle ports are
    totally plugged up, the engine will only run on the choke, which isn't
    a choke at all, it's a rod or cable operated valve that opens when the
    rider moves the "choke" lever to the ON position.
    The little valve opens to allow gasoline to be sucked directly out of
    the float bowl. But the rider discovers that the engine will only run
    on the choke and when he opens the throttle it jerks and stalls because
    the idle jets and idle passages are all plugged up
    But fresh gasoline has alcohol additives that are designed to clean out
    the idle mixture passages and jets. The alcohol starts working, but it
    works too slow.
    The best way to clean the carbs out quickly so you can ride is to put
    about 4 ounces of Berryman's B-12 Chemtool Choke and Carburetor Cleaner
    in a full tank of gasoline and go for a slow ride while the xylene,
    acetone, and methyl alcohol clean out the passages.
    If you cannot buy B-12 in a place where people named "Prashant" live,
    try a carburetor cleaner made locally that doesn't have "petroleum
    distillate" in it. That sort of fuel system cleaner is for fuel
    injection systems.
    As you ride your motorbike with the B-12 or the carburetor cleaner in
    the gasoline, you will notice that the engine idles too fast and you
    will want to turn down the idle RPM using the master idle knob
    underneath the carbs.
    Turning the idle knob down causes the carburetor butterflies to cover
    up the transition ports that give the engine extra gasoline for
    acceleration when you first open the throttle to speed up.
    The transition ports aren't supposed to be uncovered at idle RPM, but,
    when the rider first noticed the engine was idling to slow and he
    turned the idle RPM up, the transition ports were uncovered. But, since
    the idle mixture passages were already getting plugged up, the engine
    RPM didn't run away.
    If you are not the first owner of this motorbike, you should take a
    mirror and look at the underside of the carburetors, just forward of
    the float bowls. If you can see a slot headed screw in a hole there,
    the anti-tamper plugs were probably drilled out by a previous owner,
    and amateur tuners always make the mistake of turning the idle mixture
    screws too far counterclockwise, thinking that this will make the
    engine idle faster.
    When they go too far, the idle RPM actually slows down, and they turn
    the master idle knob to raise the idle speed to the correct RPM. But
    this uncovers the transition ports that I previously described, and the
    engine idles at a very high RPM.
    B-12, Aug 22, 2006
  3. Or maybe a problem in the mechanical linkage between the
    choke lever and the choke, like he says.
    Since the problems began when he tried to turn on the chike,
    I'd definitely look for a problem in the choke cables and/or
    return springs. Frayed cable or non-functional return spring
    is a reasonable suspect.
    You been sipping the B-12 again ?
    Rob Kleinschmidt, Aug 22, 2006
  4. If the choke is stuck closed due to linkage problems the engine will
    eventually drown in gasoline and stall out. Naturally he should check
    the choke linkage but the problem symptom is classic dirty carbs,
    like B-12 said.
    Ted
    Ted Mittelstaedt, Aug 23, 2006
  5. jois.de.vivre
    B-12 Guest
    That motorbike doesn't even have a choke.
    Go look at the parts diagrams on the website of your choice and find a
    spring associated with the starting enrichener mechanism.
    You been sipping the EDTA?
    B-12, Aug 23, 2006
  6. Dirty carb problems are not limited to constant vacuum carbs.
    Any kind of carb works well when it's clean but then works like crap when
    it's passages get all varnished up.
    It does not work at all if the passages are completely plugged up.
    No, the best way is to put a 50-50 mix of gas and berrymans in
    the float bowls, as you have detailed before, and cross your fingers
    and hope that the mixture passages are still passing some small amount of
    fuel.
    If they are not, and this does not work, then take the carbs into a place
    and have them ultrasonically cleaned. Do not screw around with drilling
    plugs and such and passing wires through orifices.
    Then before putting the carbs back on, make sure that they are visually
    synchronized, as the former owner who let them get all gummed up may
    have screwed up the synchronization in a desperate effort to get things
    to work.
    There are 2 kinds of carburetor cleaner out there. The first kind is the
    kind you dunk the entire carburetor into to soak it. This is not the kind
    that you pour into the gas tank and is not what you want. What you want
    is more along the lines of "fuel system cleaner"
    Most "fuel system cleaners" particularly those sold in mass-market stores,
    are in fact of the "petroleum distillate" kind.
    Ted
  7. You're saying there's a choke mechansm with a mechanical
    linkage and no load mechanism to cause it to return to off
    when you put the choke lever to off ?
    Pehaps that's the problem.
    Rob Kleinschmidt, Aug 23, 2006
  8. jois.de.vivre
    B-12 Guest
    I seriously doubt that the plunger spring is the source of the OP's
    high idle RPM problem, even though there are four springs, one on each
    plunger.
    The sliding operating mechanism grips the end of each plunger and the
    plungers all have to move together. So, even if there was a problem
    with one spring, that plunger would still be pushed shut by the
    movement of the mechanism.
    The most likely diagnosis is that his idle passages and idle jets are
    clogged up and that he has turned the master idle knob too far and the
    butterflies have uncovered the transition ports making the fuel air
    mixture far too rich for the load at idle.
    B-12, Aug 23, 2006
  9. Plungers in an enrichener circuit ?
    I would agree with your diagnosis except for his statement that a
    whole new set of problems and symptoms started after he tried to
    use the choke and continued after he put the choke off again.
    That leads me to suspect something not really returning to
    an "off" position. Most likely a cabling issue.
  10. jois.de.vivre
    B-12 Guest
    That's what the little cylindrical thingumbobs are called.
    When the owner lets his motorbike sit until the idle circuits plug up,
    the symptom is that the engine runs on the choke, but won't run when
    the throttle is cracked open.
    The, when it runs a little better, he turns the master idle knob,
    uncovering the transition ports.
    But the transition ports are plugged up. As the engine runs more,
    alcohol additives in the gasoline begin to clean out the idle circuits.
    Fuel begins to flow out of the transition ports. The idle RPM runs
    away.
    B-12, Aug 24, 2006
  11. It's fine if you want to assume he fiddled with the idle afterwards
    but that's not what he said:
    That sounds like a mechanical binding problem to me. To get to
    clogged jets, you've got to read stuff into his problem description
    which he never told you.
    Taking his description at face value, which is usually a good
    starting point, it says mechanical linkage rather than fuel flow.
    Rob Kleinschmidt, Aug 24, 2006
