Fitted them to the dipped and main beam today. Hid the ballasts away nicely (well, they're in view if you know where, as their spec does mention running temps upto 120 deg C I thought I'd better give them some air flow, and not to close to the plastic petrol tank) Went out for a play when it got dark. Main beam is OK for flashing, dim to start with from the riders POV, but after 20 secs is "sun" like, fuck me. Dipped beam isn't as crisp a cut off as I'd like and is definitely too high, even adjusted as far down as it'll go. I don't think I put the bulb in properly, or its bent or summat. Its bright though. Dipped to be dismantled tomorrow to inspect why its so high. (the R1200GS uses H7 bulbs, single element per light, and the reflector does all the beam shaping so I'm a little suprised at the poor beam cut off, hopefully it'll improve once the height problem is sorted) One thing that suprised me is the wires going to/from the ballast were a little warm after 30 mins. Specified at 101% of the bulbs rating to save costs I suppose.
