HID lights: Diane-Shop
Discussion in 'UK Motorcycles' started by Catman, Mar 3, 2008.
  1. Catman
    Catman Guest
    Rock, much.
    www.cuore-sportivo.co.uk
    Catman, Mar 3, 2008
  2. Catman
    Greybeard Guest
    Are these the dipping H4 type? if so, Does the dipping work properly?
    I'm looking to put a Dipping one on the Harley, but I'm not sure how big the
    ballast unit is, or where I can mount it.
    TIA
    Greybeard
    FLHR -03 UK (95 cu-in Stg 2. Big Boy2!)
    Trumpet Trophy 1200-03
    Garmin Zumo 550, To get me home!
    ukrm@foxtails[dot]co[dot]uk
    Greybeard, Mar 3, 2008
  3. Catman
    Catman Guest
    Nope, single beam H7, sorry.
    Mate had the dippers, they seemed to work fine. Ballast is about double
    a pack of fags.
    Catman, Mar 3, 2008
  4. Catman
    Greybeard Guest
    Right,
    Hiding 2 packs of fags in the headlight, for a non-smoker might be a tad
    difficult! ;o)
    Can I get help from the NHS quitline, to fit it?
    Greybeard
  5. Catman
    Catman Guest
    Mine live in the fairing :)
    I'd suggest a mechanic, TBH.
    Catman, Mar 3, 2008
  6. Catman
    Greybeard Guest
    Luckily, I only have to fit 1 ballast. I hope it'll fit in the headlamp
    nacelle of the "King".
    I'll have to go private then ;o)
    Nah, I'll fit it myself. I'll let you know how it goes as I've just bought a
    Bi-Xenon kit from said shop.
    Greybeard
  7. Catman
    Greybeard Guest
    Noted.
    Thanks for the info.
    I'll certainly have a better chance of hiding a single pack of fags behind
    the headlight. Is this a pack of 10 or 20? ;o)
    Greybeard
    Greybeard, Mar 4, 2008
  8. Catman
    Greybeard Guest
    It's gonna be tight.
    Watch this space, in a couple of weeks it might be for sale if I can't get
    it to squeeze in.
    Greybeard
    Greybeard, Mar 5, 2008
  9. Catman
    Yep, I'd vouch for that. Got another one for my main beam... makes for a
    nice little pair of lights.
    Muck, Mar 7, 2008
  10. Catman
    Catman Guest
    I think I can get a single for my main, which will be nice. I need to do
    the cars now.
    Catman, Mar 7, 2008
  11. Catman
    Greybeard Guest
    Are they _that_ good that it's worth doing the car as well?
    I've been thinking of doing mine for a while, but wasn't sure it was worth
    it, so thought I'd try the bike first.
    Greybeard
    Greybeard, Mar 7, 2008
  12. Catman
    Catman Guest
    I think so, yes.
    I'll prolly only do the dips, though. There is surprisingly little space
    to fit stuff under the bonnet of my 156.
    Catman, Mar 7, 2008
  13. Catman
    Greybeard Guest
    Bollox.
    I can't get it to squeeze in!
    The lamp itself sticks out the back by about an inch or so, and I haven't
    got the space to jam it in.
    I might buy another to match it and put them in the Trumpet.
    Then again, I might just flog this and forget it?
    Greybeard
    Greybeard, Mar 11, 2008
  14. Catman
    Catman Guest
    Which type is it again?
    Catman, Mar 11, 2008
  15. Catman
    Greybeard Guest
    H4 - 3 Bi xenon, the dippy h4 one.
    Not only does it have the ballast unit, but it also has another control box
    gizmo. These I could hide under the tank, but I can't get the actual lamp
    unit in the headlamp because the magnetic part sticks out the back quite a
    way.
    I'll have a look during the week, when I get time, to see if I can get it in
    the Trumpet, if so, I'll prolly buy the other and shove a pair in.
    Bloody good service from Dian-Shop though, super quick considering from HK,
    pricey delivery though, but then again, it was very speedy.
    Greybeard
  16. Catman
    Catman Guest
    Arse. Would have bought it from you.
    Indeed. Shame they don't do H7 in singles. Anyone want to go halves on
    a pack?
    Catman, Mar 12, 2008
  17. Catman
    Greybeard Guest
    Cant help you on that one I'm afraid.
    But I could do with a pair to fit the jam-jar!
    What bike takes H7 then? I take it that it'll be a two headlamp model & one
    will be dip & one main?
    Greybeard
    Greybeard, Mar 12, 2008
  18. Catman
    Catman Guest
    The Sprint ST 1050 has 3 H7. Two for dip, one for main.
  19. Catman
    Greybeard Guest
    ok.
    Can you get the three ballasts hidden away? or do you just use the one for
    the dip?
    Greybeard
  20. Catman
    Catman Guest
    Not got a main, yet. I have the ballasts for the dips in the little
    fusebox / toolkit cubby in the fairing. I wouldn't get a third in there,
    but I suspect there would be enough space elsewhere.
