HG Pants, is it me or are they "pants" ?
Discussion in 'UK Motorcycles' started by YTC#1, May 3, 2010.
  1. YTC#1
    YTC#1 Guest
    I don't expect something to be 100% water tight, but I expect better when
    I have spent so much on a pair of HG pants.
    On the way down on Wednesday, the best description would be that during
    the rain my arse felt "moist", and although things seemed dry when we got
    to Tim and Anne's I would still say I felt "claggy".
    Then, after the rain hit near Calais I had the same "moist" feeling again.
    On inspection at Calais (dropping hands in pants, it does not feel like
    they were damp. However when we got home, man hours later, Jean did say
    that my long johns felt damp.
    To me it felt like there was some "wicking" of moisture going on.
    Although I bought these in December, it is their 1st real proper rain
    test, my jacket s fine and the top half is dry
    So, before I take them back to HG, what are other peoples opinions ?
    Is it normal ?
    Am I expecting too much ?
    Will they just tell me to treat them with waterproofing ?
    YTC#1, May 3, 2010
  2. YTC#1
    zymurgy Guest
    My top half was covered in a fleece and a HG textile jacket. It stayed
    watertight, but seemed to lose its insulating properties after being
    drenched for 3+ hours at 80+
    If they're Gore-Tex, they shoudn't need proofing. The waterproof
    membrane is sandwiched within the material. If they're not Gore-Te, a)
    Why not and b) if they're nylon they should have taped seams to make
    them watertight
    I was wearing a pair of cheap ski salopettes over my leathers, which
    seemed to do the trick with no dampness. They did feel a bit moist in
    the crutch (fnar) where the tank had been funneling most of the rain
    though.
    My new boots were watertight (better than the shagged out Prexsports I
    replaced them with)
    Not bad overall, but I should have stopped and put on the extra
    jumper ..
    Paul.
    zymurgy, May 3, 2010
  3. YTC#1
    Simon Wilson Guest
    I have the HG cruise trousers, also not cheap. In heavy rain I
    experience the same dampness. I put it down to the Goretex not being
    able to 'breath' when its effectively completely underwater. So, rather
    than water getting in, it's vapour not being able to get out.
    Just a theory.
    Simon Wilson, May 3, 2010
  4. YTC#1
    Nige Guest
    I have cruise ones from HG & have never had this happen to me?
    Maybe it's sweat?
    Nige,
    Land Rover 90
    Yamaha R1
    Range Rover Vogue
    Nige, May 3, 2010
  5. YTC#1
    Tim Guest
    <snip>
    Probably sweat or condensation. My HGs didn't leak but that pooling
    sensation on the ride home was unpleasant.
    Tim, May 3, 2010
  6. YTC#1
    Beav Guest
    It sounds to me like they've not got a breathable liner so it's your sweat
    that doesn't eveaporate making it feel like you've got a damp arse. I had
    the same thing with some pants I got from J&S, so I took 'em back.
    They seem to work OK if you've got a "wicking" undersuit on though.
    Beav, May 3, 2010
  7. YTC#1
    Beav Guest
    Same theory as mine Simon.
    Beav, May 3, 2010
  8. It happens that YTC#1 formulated :
    Moisture from the inside (sweat) possibly.
    Harry Bloomfield, May 3, 2010
  9. YTC#1
    Salad Dodger Guest
    imo, yes.
    imo, yes.
    It's worse on the Wing, as I effectively sit in a shallow bowl of a
    seat. The seat will fill up with water, unlike the seat on a
    motorcycle.
    My arse *felt* damp, but no dampness was evident on me shreddies.
    Mirrors my theory. Plagiarist!
    Salad Dodger, May 3, 2010
  10. YTC#1
    YTC#1 Guest
    I had 3 layers on under neath, so insulation was OK.
    They have the big FOAD words, GORE-TEX.
    As happens with moots waterproofs IMO, it is always funnelled from the
    tank.
    YTC#1, May 3, 2010
  11. YTC#1
    YTC#1 Guest
    On Mon, 03 May 2010 10:11:51 +0000, YTC#1 wrote:
    All
    Ta.
    The breath/sweating theory sounds about right. I had taken my inner
    lining out and maybe that would have prevented the dampness.
    YTC#1, May 3, 2010
  12. YTC#1
    mark Guest
    Sometimes, motorcycling can get exciting and you may 'glow' a little.
    I think the rain outside makes this feel cold.
    It happened to me when I first got mine and I hardy notice it now.
    Main thing is; I haven't got wet in them yet.
    I think so but I haven't tried any of them really expensive waterproofs.
    They might give you new ones and eBay the ones you have?
    mark, May 3, 2010
  13. YTC#1
    probably - I've found a wicking layer, even in summer, adds to comfort. I
    wear a pair of EDZ leggings although merino wool is supposedly better
    wessie, May 3, 2010
