Hey you racer-types:
Discussion in 'Australian Motorcycles' started by Knobdoodle, Mar 10, 2007.
  1. Knobdoodle
  2. Knobdoodle
    Warren Guest
    It can help to reduce chatter and reduce them grabbing when first applied.
    Waz
    Warren, Mar 10, 2007
  3. Knobdoodle
    Thanks but doesn't it reduce braking effect overall?
    What's the point of having 6-pot mega-callipers but then cutting back the
    pads to reduce the effect?
  4. Knobdoodle
    alxr Guest
    Chamfering angles/radiuses the leading edge of the brake pad material.
    The braking effect is related to the total pad surface area ....not in
    having a 90 degree "sharp" edge presented to the braking rotor surface.
    Their is a negligible fraction of total contact surface area removed by
    angling the edge of the braking material that presents to the traversing
    rotor.
    One desirable characteristic of the braking effect is consistency of
    operation...chatter and sudden grabbing can upset suspension, traction and
    also distract the rider's attention budget.
    The above response may or may not have been affected by the consumption of
    single malt scotch within the prior 25minutes.
    Caution should be exercised before applying any of the observations evident
    in the above rambling thoughts of apparent consciousness.
    alxr, Mar 10, 2007
  5. Knobdoodle
    alxr Guest
    feck...made speiling mistake so their
    alxr, Mar 10, 2007
  6. Knobdoodle
    Smiley Guest
    It should be noted that most if not all manufactures are going back to 4
    piston
    callipers. One of the benefits of reducing the pad area helps to increase
    pressure
    on the contact point. A good example is if you go skiing the longer the skis
    the faster
    you go. Friction is the ability of two items to slide. once the parts are
    sliding you
    need to increase pressure to stop the sliding. you can put more pressure on
    a smaller
    part. there are many things to take into account when doing this. If you go
    to small
    then it has the reverse affect. this is due to the heat build-up. This is
    one of the reasons
    the wave discs improve braking. They reduce the contact area, this increases
    the
    pressure that can be applied and the waves allows air to pass between the
    pads
    helping them to cool. the increased edge surface area of the disc helps the
    discs to
    cool as well.
    Smiley.
    Smiley, Mar 10, 2007
  7. Knobdoodle
    Thanks.
    Clem
    Knobdoodle, Mar 11, 2007
  8. Knobdoodle
    Fwoar Guest
    erm - Daytona 200
    Wheels get replaced very fkn quickly ( we talking 9sec pitstops) & the
    chamfer on the leading edge of the pad allows the disk to slot home easier
    than hitting on a leading edge of a pad.
    Nothing to do with performance, just to save time in them pitstops
    Fwoar, Mar 11, 2007
  9. Knobdoodle
    Ahh of course!
    Now why didn't I think of that....
