Hey Jules and stalling
Discussion in 'Australian Motorcycles' started by bikerbetty, Jun 27, 2006.
  1. bikerbetty
    bikerbetty Guest
    I remember you saying you were coming to Canberra in late June.....
    Rug up - we've had a couple of minus 7 mornings!
    Related to the freezing weather is this question for any other
    cold-weather dwellers/riders...
    Is there anything I can do to stop the GPX stalling every time I gear
    down at lights? As soon as the temps fall below zero (and we get a lot
    of that here) I have a bugger of a time at lights- and it's a bit scary
    when cars come hooning up behind me and I'm frantically trying to
    restart the engine, especially as it's still dark at that time....
    Any suggestions? (apart from the obvious *take the bus*, ha ha)
    thanks
    betty
  2. bikerbetty
    Dale Porter Guest
    I would have thought the obvious was to get out of Canberra.
    Dale Porter, Jun 28, 2006
  3. Wasn't there a problem with (some) Kawasakis and icing fuel bowls?
    Someone will be along soon with the answer.
    Kind regards
    Dave Milligan
    Dave Milligan, Jun 28, 2006
  4. bikerbetty
    FuTAnT Guest
    Yeah, rather common problem with the ZX6/9 etc ranges from a number of years
    back, not sure if things like the GPX has similar problems though. It would
    show itself while riding along though, not at the lights. More than likely
    the thing is just bloody cold and may need a touch more fuel at idle (richen
    it up a bit in winter) and the idle speed adjusted correctly.
    Of course, it could be something more complex, but that'l solve it in the
    mean time.
    Cam
    FuTAnT, Jun 28, 2006
  5. bikerbetty
    bikerbetty Guest
    Thanks for the suggestions, folks - major service is due, so will ask
    for the idle speed to be adjusted and hope it makes a difference.
    Blipping the throttle hasn't made any difference at minus 7 (sounds
    nice though, hee hee, just before it dies!)
    betty
    bikerbetty, Jun 28, 2006
  6. bikerbetty
    There was a young fella from Cooma posting here a while back who had a
    newish (~2003?) GPX250 that had carburettor de-icing hosework fitted as
    standard. I never had carb icing problems with The Jackal even on
    those -6C mornings commuting from Tarago to Canberra, maybe they had
    problems with properly cold weather though?
    (Waiting for a puerile followup from Big/Pat/Clem...)
    BT Humble, Jun 28, 2006
  7. Soory Betty, the date got brought forward, and I've been and gone again. Of
    course it rained a little bit, so it wasn't as cold as I was dressed for.
    Sigh...
    Jules
    Julie and Deb, Jun 28, 2006
  8. Tee hee, he said "puerile"!, Sounds like booth!
    big (I'd _hate_ to disappoint you there Ben!)
    Iain Chalmers, Jun 28, 2006
  9. bikerbetty
    bikerbetty Guest
    Erk! You can keep that..... you and the penguins... I prefer it to hit
    the zero mark before 10am...
    I don't actually mind the cold - prefer it to the heat, anyway.... and
    it was one of my main reasons for moving to Canberra. Gotta love that
    crisp sparkly cold! (Well, as long as I'm dressed for it!) Every part
    of me is warmer on the bike (apart from my fingers) than I ever was on
    the bus, and I don't have to sit and muck about getting ice off the
    windows before I can leave the driveway, the way I used to in my car.
    If the stalling problem would go away I'd be a happy little vegemite.
    Let's hope Uncle Bruce can fix it, or at the very least, make it a bit
    better...
    Somebody earlier in this thread mentioned the Cooma guy and the warming
    hoses - a friend was telling me today that you can get them fitted -
    which leads me to even more questions - how expensive? and would it be
    worth it on a '97 bike... (albeit a hardly used one...had only 20,000
    on it when I got it, and only has 32,000 now) that I don't intend
    keeping for more than about another year...
    betty
  10. This site is all about your bike: http://www.ninja250.info/index.htm
    and this page is all about cold weather and carburettor jetting:
    http://www.ninja250.info/maintenance/maintain/carbs/duke4.htm
    Both altitude and latitude can change jetting requirements, so if your
    bike originally came from Brisbane and hasn't been re-jetted for
    Canberra, you should ask your mechanic to check this at the service.
    Andrew McKenna, Jun 28, 2006
  11. bikerbetty
    IK Guest
    Being female, chances are Betty already has enough trouble getting
    mechanics to take her seriously.
    IK, Jun 28, 2006
  12. bikerbetty
    Ufo8mydog Guest
    bikerbetty,
    the stalling is quite common on any carbie'd bike below 0, in Canberra.
    (at least, from my experience in Canberra winters, anyway). Some bikes
    are more sensitive to it than others.
    Being naked and unfaired, my poor little Virago is extremely sensitive
    to temps at or below -5, but the other bikes I have owned (which had
    fairings), only started having issues at -7 or -10. The cold wind/wind
    chill factor can also help the freezing process, even if the temp isn't
    that low.
    It gets worse when it is very foggy and below 0 at the same time. This
    means that the dampness soaks everything, and then freezes solid on
    whatever it settles on. (the carbies freeze up, then makes the bike stop
    when you stop at lights).
    It is nothing unusual in Canberra winter temps, and I doubt very much if
    it is anything to worry about, mechanically speaking, apart from being
    very annoying when it happens.
    I might catch the bus if its below -6 tomorrow...
    Ufo8mydog, Jun 28, 2006
  13. bikerbetty
    sharkey Guest
    Probably just upping the idle slightly will work.
    Don't worry about it, it's almost certainly not carb icing.
    (IK's point about jetting is that Canberra isn't at enough of an
    altitude to need jetting changes. HTH.)
    -----sharks
    sharkey, Jun 28, 2006
  14. bikerbetty
    bikerbetty Guest
    No, only car mechanics have been like that with me. The bloke I take
    the bike to is terrific - explains stuff to me, shows me stuff
    (probably because I sound interested and he knows I want to learn about
    it.) Besides, his workshop is only small and he only has one offsider
    - I find set-ups like that are always more helpful.
    Don't know what some of the bigger places would be like...
    betty
  15. bikerbetty
    Theo Bekkers Guest
    The coriolis effect?
    Theo
    Theo Bekkers, Jun 29, 2006
  16. bikerbetty
    sharkey Guest
    Feel free to gratuitously plug ...
    -----sharks
    sharkey, Jun 29, 2006
  17. You're both right, I was wrong. I believed that it only took 1000' of
    elevation but it's more like 1500m. And I daresay that swamps
    temperature variation, but I would have thought ideal jetting for a
    Brisbane winter isn't right for a Canberra winter?
    Andrew McKenna, Jun 29, 2006
  18. bikerbetty
    bikerbetty Guest
    Cool!
    <gratuituous plug>
    Bruce's Motorcycles - Grimwade St Mitchell. I think Bruce is great
    because he takes me seriously and listens to my concerns about my bike.
    It doesn't matter that I'm a little woman on a little bike, and have
    L's, and the first time I picked up the bike after a service I admitted
    to being too scared to ride it away from the workshop in peak hour (you
    know we have a SHOCKING peak hour in Canberra, right???<snigger>). He
    actually understood that and didn't make me feel like an idiot - and
    has thus earned my undying loyalty.
    Women riders are on the increase, like it or not <grin>, and mechanics
    who don't treat them like idiots are going to be the big winners in the
    long run.
    I told Bruce about the stalling problem and we had a bit of a chat
    about the whys and wherefores, and it all tallied with what you guys
    (and other friends) have said. He's adjusted the idle speed a bit and
    now I'll just have to see how it goes. Sounded good on the way home
    from the workshop (in peak hour this time, YAY!!!!!)
    Thanks for your responses folks - fingers crossed for tomorrow morning
    on the way to work in the frost!
    betty
    bikerbetty, Jun 29, 2006
  19. bikerbetty
    You'd think he'd move to Bruce!
    OK Canberra aus.motians; I think motorcycle-mechanics 101 is in order for
    Ms Betty!
    Never again do I want to hear "My mechanic adjusted the idle speed..."
    Knobdoodle, Jun 29, 2006
  20. bikerbetty
    Hammo Guest
    I'll move to Canberra. Who wants to pack all my stuff up?
    Hammo
    Hammo, Jun 29, 2006
