I'm new to this group, but not a usenet noob. I didn't see a FAQ posting, so if I step on any toes with my question, I apologize in advance. My 03 VN1600 has a steady oil leak, maybe a teaspoon every three or four hours. I pulled the left side engine cover and and it looks like I'm getting a drip forming at the bottom of the Clutch controller housing beneath the bottom bolt near where the cable meets it. It's not clear that the controller is the source of the leak, but if anyone has seen this and has any suggestions I'd appreciate the advice. Also, there are two plastic plugs on the Generator cover. I pulled the top end plug and noted there was no oil in there. I pulled the center plug and there was no oil at that level either. Is this lubed by the crankcase sump or is this supposed to have some other lubricant in there? I can't find it referenced in the owner's manual. Thanks for any help you can offer Dave
