[QUOTE] Insanely Sensible [email][/email] says... Start it up, put front brake on, stick it in gear. If it stalls its not worked. If it doesn't it worked.[/QUOTE] I may be being thick but couldn't you put it in gear, with the engine off, pull the clutch lever in, and if you can roll it forwards then the clutch isn't sticking. If you can't then it's engaged still.
