Help needed
Discussion in 'UK Motorcycles' started by Insanely Sensible, Mar 6, 2005.
  1. I have my GPZ500 up for sale.
    Its been off the road for close to 10 months, for various reasons.
    Today someone came to look at it, and took it for a test ride, and
    apparently the clutch has seized. I know nothing in the way of mechanicals,
    so what I am after is:
    1: someone that knows about these things that can offer any advice
    or
    2: someone in the Chesterfield area that would be willing to take a look at
    it for me
    Thanks(hopefully!)
  2. Insanely Sensible
    Stonge Guest
    Cable needs oiling?
    Stonge, Mar 6, 2005
  3. New clutch cable. Cost about 15 quid.
    The Older Gentleman, Mar 6, 2005
  4. Cable seems fine, seems to be the clutch itself not doing what clutches
    should do.
  5. Cable is moving freely, and is moving the part on the clutch housing, but
    clutch is not disengaging.
  6. Insanely Sensible
    Eiron Guest
    Any plates visible through the oil filler hole?
    You could, after tying the lever back, apply a little force
    with a screwdriver.
    How did the prospective purchaser manage to test ride it?
    Eiron, Mar 6, 2005
  7. Insanely Sensible
    mups Guest
    Insanely Sensible says...
    The plates have stuck together. Tie-wrap the lever back to the bars and
    leave it overnight.
    mups, Mar 6, 2005
  8. Done that.
    Next stupid question is how do I know if its worked or not, bearing in mind
    I can't road test it?
  9. I wasn't here at the time, so I don't have first hand witness information,
    but apparently managed to get it into first, to the end of the road, where
    on braking and pulling in the clutch it did a bit of a rear wheel shimmy and
    stalled.
  10. Erm, why can't you road test it?
  11. le force
    It's very unlikely for a clutch to stick. Have you considered the
    possibility that the purchaser couldn't actually ride?
    Anyway, as soon as SWK rides it, it'll become clear enough.
  12. Insanely Sensible
    'Hog Guest
    This sounds odd but it works. Take the friction plates out, assuming you
    can dismantle the clutch. Degrease them, boil them in cheap bleach for 5
    minutes, re-install. This is assuming it doesn't free off anyway.
    'Hog
    'Hog, Mar 6, 2005
  13. No license
  14. Without the engine on, put it in gear, let the clutch out, push it.
    You'll soon know.
    I bet you'll have to take the clutch out and separate the plates.
    Messy job. good luck.
    ColonelTupperware,
    spouting bollocks on Usenet since 1997
    Usenet FAQ at
    http://www.its.caltech.edu/its/services/internetapps/news/news2.shtml
    UPCE FAQ at http://upce.org.uk/ UKRM FAQ at http://www.ukrm.net/faq/
    Colonel Tupperware, Mar 6, 2005
  15. Thank you
  16. Insanely Sensible
    mups Guest
    Start it up, put front brake on, stick it in gear. If it stalls its not
    worked. If it doesn't it worked.
    mups, Mar 6, 2005
  17. Colonel Tupperware, Mar 6, 2005
  18. So, erm .. why can't you road test it ?
    genuine_froggie, Mar 6, 2005
  19. Ah, right, as you were then.
  20. Yes, I re-read the posting after I'd added mine and saw that it had been
    standing for 10 months, in which case it's very likely. Mea culpa.
