Help me!
Discussion in 'UK Motorcycles' started by Stefan, Dec 31, 2004.
  1. Stefan
    Stefan Guest
    Any help here would be VERY much appreciated!
    On my 97 speed triple, yesterday I noticed a strange (and new)
    phenomenon! When in neutral, as I release the clutch and "engage"
    neutral there is a REAL increase in the general bike's vibration. When
    I pull the clutch in or am in a gear there is no problem, but when I
    am at the lights in neutral with both hands off the bars there is a
    weird change in noise and vibration.
    WHAT ON EARTH COULD THIS BE?
    And even better, how could I fix it?
    Thanks in advance.
    Best response gets a mystery star prize as I really want to sort this.
  2. Stefan
    Salad Dodger Guest
    Clutch rattle. Learn to live with it.
    Don't buy a Honda, cos they do it too.
    | ___ Salad Dodger
    |_\_____/_| ..73063../..17250.../..3180./.19406
    \|^|/ ANORAK#17 IbB#4
    Salad Dodger, Jan 1, 2005
  3. Stefan
    My FZR250 has clutch rattle too, and it gets really loud when the carbs
    need balancing.
    Muck, Jan 1, 2005
  4. Stefan
    Tim Guest
    Check your oil level. It may be low but not low enough to light the
    warning bulb.
    Tim, Jan 1, 2005
  5. That's why mine rattles then, either that or it's the cam chain.
    Whinging Courier, Jan 1, 2005
  6. Stefan
    mups Guest
    Whinging Courier says...
    Its a CBR thou. They all fucking rattle.
    mups, Jan 1, 2005
  7. Mine didn't start rattling until a few weeks ago. More of a fast ticking
    noise, actually that gets quieter when it feels like it and then comes
    back again.
  8. Stefan
    Does it seem louder after a hot start or when cold, or is it truly random?
    Heh.. did you hear how much my FZR250 rattled before I started adjusting
    it? :)
    Muck, Jan 2, 2005
  9. Stefan
    Also, maybe the clutch plates and primary drive gears rattle, like wot
    my FZR does.
    Don't those bike engines sound a little rattly at idle anyway?
    Muck, Jan 2, 2005
  10. I've only noticed it when it's cold. It could do it when hot but I've
    not noticed it then. When it starts cold, it'll tick and then it'll get
    quieter after a few seconds and then it'll come back. I've not listened
    to it carefully but from what I remember it never really goes away but
    gets quieter.
    I'll go out on it today and try to remember to listen to it when it's
    warm.
    No. I don't think I've ever heard your FZR at anything above idle.
    Whinging Courier, Jan 2, 2005
  11. Stefan
    Tim Guest
    Not on my '98 Daytona. The other thing that comes to mind is how long
    since it was last serviced? You may just need clean plugs or the newest
    engine mapping for the ignition. Engines slightly off-tune do make odd
    noises.
    Tim, Jan 2, 2005
  12. Stefan
    Sounds most likely the valves want checking and adjusting. Lovely job,
    which usually involves taking the cams out. :)
    That's when it rattles most.
    Muck, Jan 2, 2005
  13. Yes, could very well be.
    Are you sure they need to come out or have you got a cam fetish?
    Whinging Courier, Jan 3, 2005
  14. Stefan
    You going to get it done then?
    My fetish isn't cams, although I do still keep a couple of bits of
    Bandit cam in my broken bits tin.
    At 18,000 rpm all the noise just seems to blend and become a scream.
    Muck, Jan 3, 2005
  15. Only if I can get it done without paying for it.
    I know what you mean. My tank vibrates now and at a certain rev it makes
    the bike sound like it's growling.
  16. Stefan
    mups Guest
    Muck muck@_TEETH_tallbloke.net says...
    Luckily the CBR is good old screw and locknut. The exhaust valves on 1
    and 4 are a bit of a bugger to reach mind.
    mups, Jan 3, 2005
  17. Stefan
    Wow, cool. Piece of piss then.
    Muck, Jan 3, 2005
  18. Stefan
    Get a Hanes Manual or borrow one, and I'll give you a hand with doing
    it. You could pop up, as I've got tools and stuff here...
    On my CG125, I know when the tank is half empty, as it sort of howls at
    full cruise speed. Funny what you notice about your bikes when you get
    to know them.
    Muck, Jan 3, 2005
  19. Stefan
    mups Guest
    You're welcome to borrow my HBOL and my gauges if you want to do the
    carbs as well.
    mups, Jan 3, 2005
  20. Stefan
    Excellent, sounds like a plan dunnit WC?
    Muck, Jan 3, 2005
