Hi everyone, I have a Teapot and it's not too well. It has been in storage for the past year or so. I have done the following :- Stripped down carbs and cleaned the shite off them. Replaced plugs Replaced coils - S/H Replaced HT Leads and plug caps -S/H Oil & filter change. Air filter change. Clean petrol It runs really rough, and just conks out when it's not on choke. On normal idle, it dies. Strangely 1&2 don't seem to be firing right. Feeling the pipes, 1 seems quite cool, 2 a little warmer. 3&4 are hot as they should be. I have altered the idle speed to stop it dying, which seemingly worked for a time...now it just dies. Could I have wound this too far ? I have pulled the plugs of 1&2, and there is a nice blue spark so I guess this rules out the CDI (or does it) ? I am considering doing the following :- Replace the carbs with another spare set I have. Possibly check valve clearances (but feeling a little nervous about that particular job...not done it before). I haven't had the carbs balanced, but am considering it. Any ideas on what else could be wrong ? Thanks in advance, Dan
