HELP finding ECU connector
Discussion in 'Australian Motorcycles' started by GM, Jan 15, 2004.
  1. GM
    GM Guest
    Hy all.
    I'm desperately finding electronic control unit's connectors for:
    YAMAHA
    KAWASAKI
    SUZUKI
    BMW
    APRILIA
    If you could indicate me where I can find just only one of above
    connectors, please respond or contact me in private!
    Thanks in advance.
    GM, Jan 15, 2004
  2. GM
    Biggus Guest
    YAMAHA
    KAWASAKI
    SUZUKI
    BMW
    APRILIA
    they all have them, contact them...
    Biggus, Jan 15, 2004
  3. GM
    glitch1 Guest
    Try companies like Jaycar Electronics, they have block-connectors
    (male/female) blanks and the relevant pins in a variety of sizes.
    Of course you'd have to re-wire both sides of the connection for a match
    (check number of pins used @ the OEM connector first)
    cheers
    pete
    glitch1, Jan 15, 2004
  4. GM
    sharkey Guest
    You'll find it a bit tricky, I'm afraid ... the connectors
    they use are pretty weird. Might be worth trawling the
    wreckers for written off bikes -- even if most of the
    wiring loom is gone, the ECU connector should be rescuable.
    Wotchya doing anyway?
    -----sharks
    sharkey, Jan 15, 2004
  5. Connecting electronic control units...
    Postman Pat
    Pat Heslewood, Jan 16, 2004
  6. GM
    Frank Warner Guest
    to postmen. :p
    Frank Warner, Jan 18, 2004
