Help! Bike won't start
Discussion in 'UK Motorcycles' started by Paul Carmichael, Feb 7, 2010.
  1. And it's a lovely day.
    Battery was too low to get it going. Put it on charge for 10 minutes.
    Back on bike. Turns over enough to fire once, but immediately afterwards
    the battery is completly flat - just about works the clock. Won't even
    light the panel lights.
    What's happened?
  2. Paul Carmichael
    Nige Guest
    Either flat or fucked.
    Has it got an alarm, how old is the battery?
    Nige,
    Land Rover 90
    Yamaha R1
    Range Rover Vogue
    Nige, Feb 7, 2010
  3. Paul Carmichael
    crn Guest
    You have not used it for a while and the alarm has battened the flattery.
    This abuse has probably buggered the battery so a replacement may be
    needed. Put it on charge overnight and hope .......
    crn, Feb 7, 2010
  4. The battery went flat and you haven't left it long enough to charge.
    doetnietcomputeren, Feb 7, 2010
  5. Paul Carmichael
    consequences of bike owned by numpty
    don't you have some jump leads and a Seat?
    wessie, Feb 7, 2010
  6. I disconnected the alarm years ago. Used the bike a couple of weeks ago
    and the battery is about 3 years old.
  7. I understand that, but for the battery to go from being able to turn the
    engine, to absolutely flat in 2 seconds, sounds a bit rare.
  8. I do. That may be the next move, but I want to be sure the bike will
    start again if I stop en-route.
  9. It would be, but it didn't.
    It was already flat, but with enough juice to turn the starter once or twice.
  10. If the battery isn't fucked, and you ride it for long enough to get
    some charge in it - which is much longer than 10 minutes - then you
    should be fine.
    Alternatively, don't stop en-route.
  11. See my reply to dnc.
  12. So it was magic then?
  13. Paul Carmichael
    take the jump leads with you and don't stop in a village where the only
    transport is a donkey
    wessie, Feb 7, 2010
  14. Did you pick and eat some wild mushrooms lately?
    Okay, I suppose 'flat' could be constured as a binary term, in which case
    s/flat/really very fucking dishacarged but not quite flat.
    Empty <--^--------------------------------------------------> Full
    Trying to start the bike took the last bits of juice that were left,
    which were insufficient to fire the bike. 10 minutes of charge put some
    juice back into the battery, but not enough.
  15. Paul Carmichael
    crn Guest
    Hmmmm - 3 years is about right for a cheap battery. Next time pay the
    extra and get a Yuasa or Varta. Charging overnight might revive it.
    It is a good idea to keep any bike which is not used regularly on
    an optimate to keep it topped up. Batteries do not like cold weather.
    crn, Feb 7, 2010
  16. But I have never seen a battery go *that* flat ie; won't even light the
    ignition light. I was wondering if the kick-back might have done
    something magical to the starter which then had a word with the solenoid.
    Or something. Look, I don't know - that's why I asked.
  17. Paul Carmichael
    Simon Wilson Guest
    'Cold' in this case is probably 25C.
    Simon Wilson, Feb 7, 2010
  18. They put the small rubbish batteries in those bikes, get rid of it.
    Rot in Hell Evan Chandler, Feb 7, 2010
  19. See my other reply - either flat is binary or it isn't.
    If it is, then the idiot lights won't light.
    If it isn't, then there was enough juice to light the lights and you
    used it up.
  20. But it's a genuine Huitong! Actually, it's been on the Optimate for the
    last few months - that is - until a couple of weeks ago. It's actually
    only the bike's second battery in 12 years. I think the original was
    Yuasa. Got the latest one from Dave Wood. He told me it was a good make.
    He's a racer, so I'm sure he didn't make that up.
