Help 1981 Honda 650 Custum Starting Problem
Discussion in 'Motorcycle Technical Discussion' started by alex, Aug 7, 2006.
  1. alex
    alex Guest
    Thanks again everyone for you continued help. I will trying running
    the Berryman's through.
    To be more accurate, the big bang came out of the mufflers along with
    some puffs of black smoke.
    And the power loss is pretty severe- I can't get the bike over 30 mph.
    alex, Aug 9, 2006
  2. alex
    Ron Seiden Guest
    That bike has a vacuum cutoff for the fuel as well as the manual petcock.
    This vacuum widget cuts off fuel flow unless & until it gets engine vacuum.
    (Yes, I know it makes no sense to have no fuel flow until the engine is
    running, but I guess they figured you'd have enough fuel in the float bowls
    to get it started. Me, I just removed the vacuum cutoff and run it the old
    fashioned way with just the manual petcock -- instantaneous fuel flow when I
    want it, and I don't need a gadget to take care of me forgetting to shut it
    off.)
    I'm mentioning all this just in case yours is preventing your carbs from
    getting enough (or any) fuel to get started. Check that vacuum line for
    leaks, and make sure the float chambers are full before you try to start it
    up...
    Ron Seiden, Aug 9, 2006
  3. alex
    Ron Seiden Guest
    Something those bikes were (and still are) known for. Almost every CB650 you
    find will have a dark area on the fins just under the head on one side. It's
    a dead (from age) oil seal that looks bad but doesn't leak enough oil to be
    worth the effort of a full engine rebuild to fix it... (Keep track of your
    oil level, and if the leak becomes more significant, time for that rebuild.)
  4. I'm less familiar with US models, agreed. In the UK, we got the more
    basic earlier CB650 Custom, and we never got the upgraded model. So
    apologies.
    I owned a "straight" CB650 myself - bought one a few years ago. One of
    the most under-rated bikes I've ever owned.
    This one, though - if it's dipping on the left, it could be the gear
    lever shaft seal.
    The Older Gentleman, Aug 9, 2006
  5. You are so right. Virtually every SOHC Honda four I've owned has had a
    dark area on one side of the head gasket or the other. My current 400
    does, too. And as you say, it never looks bad enough to justify a
    tear-down. Never has got that bad, either.
  6. alex
    FB Guest
    Just as an off-the-wall possibility, as Honda was evolving from using
    ignition points to electronic ignition systems, their suppliers didn't
    seem to know how to build an electronic ignition advance curve into
    their ignition control units.
    So your Honda has a *mechanical ignition advancer*.
    Your advancer unit would be on the right hand side of the engine under
    what Honda still called the "points cover".
    It is just possible that your advancer is stuck in the full advanced
    position. That would make starting very difficult, running down your
    battery, and cause a loss of low RPM power.
    A strategically applied drop of oil might fix a faulty advancer, or
    maybe the return spring popped off.
    FB, Aug 9, 2006
