Helmets
Discussion in 'UK Motorcycles' started by Mash, Dec 30, 2003.
  1. Mash
    Mash Guest
    Start shopping somewhere else, he's pretty much bullshitting you. If he's
    willing to **** you over for a helmet, I wouldn't want to buy anything more
    expensive from there.
    So long as its got the pretty sticker in the back, it will do all the good
    it can. As a first helmet, get something like a shark, the more expensive
    ones are usally expensive because of the paint jobs on them. Just avoid the
    £50 trash which will have a seam down the centre.
    Tell us where you are and im sure someone will send you to a decent dealer.
    Mash, Dec 30, 2003
  2. Mash
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Robin
    Sit down. This may come as a slight shock.
    The salesman was lying in an attempt to get more money from you.
    The only way a more expensive helmet will protect you better than a
    cheaper one[1] is if it fits better.
    You can stand up again now.
    [1] Assuming the cheaper one has the appropriate standards marks.
    Nigel Eaton, Dec 30, 2003
  3. Mash
    Robin said...
    Understandable on his part because the more expensive helmets will boost
    his personal sales figures.
    Even the cheapest of helmets out there are designed to primarily protect
    your head in the event of a crash. However, there are varying levels of
    protection available.
    Modern safety tests, such as the ECE22-05 test, are carried out on
    specific parts of the helmet, not all over the whole shell.
    Manufacturers tend to reinforce their helmets with the carbon/kevlar mix
    in just these areas and leave the rest of the lid in plain old
    fibreglass, so if they claim things like 'Carbon fibre reinforced' or
    'kevlar' then take it with a pinch of salt, they'll normally only be in
    places where the test is performed. Some helmets, and I will name the
    latest AGV Ti-Tech[1] here, are dangerously thin in places you would
    expect to need reinforcing, namely the chinbar area. As the ECE22-05
    test is a test performed by the manufacturer and not by an independent
    outside body, it's pretty worthless in my humble opinion.
    Even the cheapest 210 quid Arai RV has a shell made from an even
    thickness of composite material all round the shell. To my mind, for
    this alone it's worth buying an Arai. From that RV to the Arai RX7
    Corsair there is a 250 quid jump, but this is mainly down to
    stronger/lighter materials being used, a different material used for the
    liner, removeable liners for washing, and a multitude of air vents. All
    these things cost money, and it's the punter who pays. Ultimately, Arai
    make quality lids, that's why they are the number one choice of the
    racers out there who have to pay for their own gear.
    There have been extensive tests on Helmets over the years, but as
    manufacturers drop models and replace them with new ones, it's hard to
    keep track on a monthly basis.
    A helmets design is such that it will deform to absorb the impact. There
    are three impacts when the helmet hits a solid object.
    1. Helmet hitting object
    2. Skull hitting inner liner of helmet
    3. Your brain hitting the inner skull
    A good helmet will absorb the shock of the first two, to minimise the
    chances of the third happening. What you have to decide is what helmet
    you feel safest and most comfortable with after you've read the makers
    bullshit.
    When I buy a helmet I don't have a problem with buying a more expensive
    one for one main reason. It generally tends to last better. I do about
    20,000 miles a year, if I were to buy a 100 quid helmet it would last me
    hardly any time at all before it started to fall apart. Liners wear out
    extremely fast on cheap lids and are not replaceable, vents fall off and
    visor fittings aren't of the best quality on the cheaper lids.
    Were you to buy something like an Arai RV at 210 quid, you get a lid
    that will last for 5 years if you look after it. If you factor that
    against a 100 quid lid that lasts you 18 months, the Arai suddenly
    becomes good value for money, especially when you consider the added
    safety aspect that it has.
    Personally I wouldn't buy any helmet at 500 quid, I do think that is too
    much, but there are good lids out there that will last 5 years and only
    cost up to 300 notes. Arai, Shoei, Uvex and the more expensive HJCs come
    to mind.
    In closing, just remember one thing. If the helmet you buy doesn't fit
    you properly, then you may as well not be wearing it no matter how much
    it costs. I have posted a guide to helmet buying and fitting on here
    before, if you can be bothered to google for it.
    [1] I sent all the brand new AGV Ti-Techs back to the importer because I
    refused to sell them at Hein Gericke. Three of them had paint faults,
    and two of them split from the base up towards the visor aperture when
    people were trying them on for size. The shells were almost toy-like in
    structure, there was almost no substance at all in this area.
    Bearing in mid this is AGV's flagship model, I was disgusted that their
    quslity control had let paint faults through on so many lids and to let
    2 helmets go out to one shop with dangerously thin shells was enough for
    me to refuse to sell them.
    Lozzo, Dec 30, 2003
  4. Mash
    Robin Guest
    When I bought a helmet the bloke in the shop wanted me to buy a
    400 quid
    one. He said that some cheaper helmets did not stand up to higher speed
    crashes. If I hit anything solid above 40 mph I am in deep doo doos
    anyway no ?
    Is there any stats on how much difference a good helmet makes ?
    I can undertsand platic plates in clothing for scraping on and leathers
    to protect skin, but I would have thought the strength of a helmet
    had limits defined by the sheer force/accelleration
    a human body can cope with.
    Robin, Dec 30, 2003
  5. Mash
    ....was worse than mine. :eek:)
    CT, Dec 30, 2003
  6. Mash
    Mash Guest
    A company that can't control their quslities shouldn't be allowed to trade
    IMHO.
    Mash, Dec 30, 2003
  7. Robin wrote
    Bloke sa ****. Name names here and shop elsewhere.
    steve auvache, Dec 30, 2003
  8. Mash
    Cane Guest
    Yeah, like a scooter ;)
    Cane, Dec 30, 2003
  9. Mash
    Cane Guest
    As long as it matches your leathers it a good one.
    Cane, Dec 30, 2003
  10. Mash
    Lozzo was seen penning the following ode to ... whatever:
    <snip lots of useful advice>
    Listen to this man, he knows what he's on about.
    Timo Geusch, Dec 30, 2003
  11. Mash
    Champ was seen penning the following ode to ... whatever:
    I'm not back, I was there all the time. But by now you've got a decent
    translation...
    Timo Geusch, Dec 31, 2003
  12. Mash
    Nidge Guest
    Ok. So now you know you cannot believe a single word the lying tw*t tells
    you ever again dontchya? Which is in fact useful.
    Short summary. You *should* get a new helmet every time you bang it into
    anything. (Only the very rich and obsessive compulsive do this). But bang
    for bang the (mostly cheap) Polycarbonate helmets are far more dangerous
    than glass, Kevlar or carbon ones as the polycarbs can get network of
    microscopic fractures after a bang which you can't see but may cause the
    thing to fail in the next impact.
    I *do* have a £400 Arai and its luvverly.
    But for off-road I just (October) bought a triple laminate Shark (minus two
    vents) at a show for £100
    Nidge
    ZX6R J2 Stunning in zit yellow. Bits of CB500S in Norwegian Parrot blue.
    BOTAFOT#63
    'Just because I don't care doesn't mean I don't understand'.
    (Homer Simpson).
    Nidge, Dec 31, 2003
  13. Mash
    Nidge said...
    I've got one of those, but mine still has all the vents, luckily. They
    aren't known for thier ability to keep the vents attached. I'm not
    bothered cos I scammed mine for free, brand new.
    Lozzo : The anti-Timo
    ZZR1100D, GPZ500S, CB250RS x3
    BOTAFOT#57/70a, BOTAFOF#57, two#49(suspended), MIB#22, TCP#7,
    BotToS#8, GP#2, SBS#10, SH#3, DFV#14, BONY#9.
    http://www.glfuk.com/ for MJK Leathers in the UK.
    Lozzo, Dec 31, 2003
