Helmet time
Discussion in 'UK Motorcycles' started by Hankjam, Apr 10, 2011.
  1. Hankjam
    Hankjam Guest
    Hope all is good.
    Trying to find a replacement visor for my AGV is proving tricky as my
    son remove all the labels from it and I don't have a clue what type it
    is and now there are no AGV stockists in this part of the world to
    have a go see... so thinking about a new one.... last one I think I've
    had for +6 years.
    I have a rather large head and finding a helmet that fits has been a
    bit of a challenge. That couple to the fact that this is only the
    second one I bought.
    So when trying on a new helmet and thinking about fit what are the
    points to keep in mind?
    Thanks for your time.
    Hj
  2. Hankjam
    Set a budget and keep trying helmets on. Don't assume you have an "Arai" or
    "Shoei" head. Usually the model you bought last time has been replaced by
    the time you need a new helmet and there is no guarantee the replacement
    will be the exact same shape.
    Make sure it fits properly. Take a friend along and get them to hold the
    helmet firmly whilst you try to move your head inside. Any movement then
    try a different size.
    I bought a new Shoei last year. I couldn't get comfortable in any of the
    stock sizes in the shop but then I realised that the cheek pads can be
    changed for different thicknesses. So, I now have an XL shell with 31mm
    cheek pads insted of the 35mm standard. That 8mm extra room makes it a lot
    easier to get on/off and more comfortable in use.
    http://sharp.direct.gov.uk/ gives details of some tests (once the website
    comes back online). I find that the tests don't always keep up with the
    frequency that makers change their models. Useful, though just to compare
    cheaper helmets with dearer ones. If you only ride short journeys then a
    £70 Lazer will give you all the protection you need. If, like me, you ride
    long trips to the Alps etc then the extra comfort provided by having an
    Arai or Shoei with their plush fabrics, fancy vents etc is worth the extra
    money, up to a point (between £200-300 for me).
    wessie, Apr 10, 2011
  3. Hankjam
  4. Hankjam
    Hankjam Guest
    <snipped>
    Thanks for the advice.
    I'm really just a commuter, 14 miles round trip, though it can get
    speedie, so wind noise is an issue.
    Hj
    Bandit6
  5. Hankjam
    Avoid a flip front then. They tend to be noisier than full face helmets.
    Wear ear plugs.
  6. Hankjam
    zymurgy Guest
    After having had to buy a cheap lid rapid pronto last Friday, I am
    more than pleased with my cheapo [1] Caberg one, with the internal sun
    visor. Recommended to the house after riding up to Derby and back both
    times in low sun ...
    Hmm, Several makers do a large lid. Just keep trying them on until
    something fits. The more expensive (e.g. Arai) do a fitting service,
    so if it doesn't fit, they'll pad it to fit.
    Other general points are ;
    Hold the chin bar and try to turn your head, it shouldn't be easy.
    Push the chin bar into your face and see how easily it touches your
    chin. In an accident this will happen a lot harder and faster.
    With the chin bar held in, is there a space between the back of your
    head and the padding ?
    Paul.
    [1] None of his sale lids fitted me, so he price matched one he had on
    the shelf with a sale one, which was jolly decent of him ..
    zymurgy, Apr 11, 2011
  7. Hankjam
    Who him? Where him?
    wessie, Apr 11, 2011
  8. Hankjam
    Hankjam Guest
    On Mon, 11 Apr 2011 12:47:32 -0700 (PDT), zymurgy
    Thanks to you and Wessie for your helpful comments. Got a top from
    Cupar Motorcycles and the boy who sold it to me went through all these
    points. They didn't have too many XL's in stock but the one (Shark) I
    got fits better than my last one. Going to take some time getting used
    to the new buckle fitting, no more two rings.
    Cheers
    Hj
    Hankjam, Apr 17, 2011
  9. Hankjam
    zymurgy Guest
    Local Yamaha dealer actually. Probably a bit of a trek for you
    unfortunately.
    If you're going to France i'll show it to you then (oo err).
    If you want a Caberg I can always pop in and get one for you.
    Cheers,
    Paul.
    zymurgy, Apr 17, 2011
  10. Hankjam
    zymurgy Guest
    No worries. The D rings are more fiddly until you get used to them,
    but the purists prefer them. I like the buckle fitting but my Arai
    uses D's so ultimately I don't mind either way. Also, my Shark lasted
    for years and years without falling apart so looks like you've got a
    decent buy.
    Cheers,
    Paul.
