Helmet comparison...........
Discussion in 'UK Motorcycles' started by doesnotcompute, Oct 11, 2004.
  1. No coal and they've switched to metal and plastic office furniture? :)
    Paul Varnsverry, Oct 14, 2004
    #41
  2. doesnotcompute
    Timo @ work Guest
    At least around London, most of the S1s I've seen already come with
    the double-D fastener instead of the seatbelt one.
    BTW, how do you like it? I'm pretty happy with mine, only downside is
    it's tendency to have the occasional drop of water run down the inside
    of the visor in heavy rain.
    Timo @ work, Oct 14, 2004
    #42
  3. doesnotcompute
    (Paul Varnsverry) struggled to ejaculate:
    Furniture? In Cumbria?
    The best most places manage is an upturned dead sheep, mate.
    Pip, Oct 14, 2004
    #43
  4. doesnotcompute
    Necrobestiality. Mmm, squishy.
    platypus, Oct 14, 2004
    #44
  5. doesnotcompute
    Verdigris Guest
    It's a bit noisy, but I can live with that.
    The ventilation is poor: it's rather stuffy in hot weather unless you're
    moving at a decent pace.
    It mists up badly: both with the original anti-mist thingy, and later with
    a FogCity insert.
    It leaks. In very bad weather, at speed, I get a fine spray of water from
    the chin vent - weather it's open or closed. More seriously, the visor
    seal leaks quite badly, compromising visibility. Only in very heavy rain,
    but I'm not happy with a helmet that I can't use under all conditions.
    Verdigris, Oct 14, 2004
    #45
  6. doesnotcompute
    Donegal Paul Guest
    Same here.
    mine was ok (just one plus) with the visor open just a touch, the decent
    pace bit doesnt apply to the scooter :)
    Mine did used to mist but again i would open the visor just slightly.
    Mine never leaked but i guess thats the (lack of ) speed I did.
    So for me its still a possibility, but thanks for letting me know.
    Donegal Paul
    Lambretta Li186 - crashed and bashed
    Vespa T5 Millenium - Wifey's (technically)
    www.thepilgrimssc.co.uk
    www.a4c.co.uk - What are YOU doing?
    www.ailishandcharlie.co.uk
    Donegal Paul, Oct 14, 2004
    #46
  7. I am very happy with my S1, although the combination of my height and
    the RT's screen creates some unusual effects.
    Noise levels within the S1 are very low when riding with the bike's
    screen in its lowest position, but with the screen in its highest
    position, the altered airflow raises noise levels to a point where
    they do not appear to be significantly different to when I am wearing
    my OGK. Schuberth draw attention to this possibility in the users
    handbook (which, as you will be aware, is about the same number of
    paes as the average motorcycle manual!).
    The environment within the S1 can also become rather stuffy in hot
    weather. The ventilation system simply doesn't shift enough air
    through, but having ridden an unfaired motorcycle on a hot day earlier
    this year, I realised it is the RT's fairing, not the S1, that was the
    cause. I switch to the OGK if I know I will be taking in any amount of
    low-speed riding on a hot day. The OGK's extra vents - and probably
    their off-centre positioning - plus the absence of a chin glove as
    fitted to the S1 make all the difference.
    My S1 also permits rain to run down the inside of the visor. It
    usually happens only at low speeds, or after a prolonged period riding
    at speed in heavy rain. I suspect rainwater builds up along the top
    edge of the visor seal, but is held there by the airflow over the RT's
    screen. As soon as I slow down, the occasional teardrop appears at the
    top of my field of vision, followed eventually by a rivulet of water
    down the inside of the visor. This doesn't appear to affect the
    excellent anti-mist properties of the coated visor, however, and I
    have certainly owned numerous helmets in the past which exibited the
    same characteristic - or much worse - and in the process washing off
    whatever anti-mist treatment I may have applied to the inside of the
    visor.
    About the only helmets I can think of which would probably not permit
    rainwater to run down the inside of the visor would be the Nava 2 of
    the 1980s and the (?) Porsche Design helmet of the same period; both
    of which had visors which were contained within the helmet's shell and
    not fixed to the outside.
    Paul Varnsverry, Oct 15, 2004
    #47
  8. doesnotcompute
    Paul Varnsverry was seen penning the following ode to ... whatever:
    Yep, same here on the Pan - I'm actually looking into fitting a higher
    screen for that reason.
    Well, during low-speed riding I simply tend to leave the chin vent
    open - the additional airflow is quite nice. But granted, it doesn't
    flow *that* much air - one of the reasons that it is so quiet, I
    believe.
    Grrr. Yep, same here. Never had that on my Shoei XR800, but both the
    S1 and the crappy X-lite flipup lid I've got do that.
    Timo Geusch, Oct 16, 2004
    #48
