Heathrow T4 bike parking?
Discussion in 'UK Motorcycles' started by JB, Jun 17, 2006.
  1. JB
    JB Guest
    Any good/safe(ish) places to park at T4 for a few days?
    Thanks
    JB
    JB, Jun 17, 2006
  2. JB
    deadmail Guest
    Not sure about T4, but if you go to T1, follow the sign for the
    short-stay parking but don't enter the car park and go straight on
    there's a secure, covered parking area.
    Opposite this you can walk into T1 arrivals and take a lift down to the
    train which takes you to T4 for free.
    deadmail, Jun 17, 2006
  3. JB
    JB Guest
    Ta. that will do nicely.
    JB
    JB, Jun 17, 2006
  4. JB
    deadmail Guest
    Prolly best to double check the train is still running etc. 'cos I
    haven't done this for a year or so.
  5. JB
    JB Guest
    There's always the longterm carpark buses. Used them many times 'terminal
    hopping'.
    cheers,
    JB
    JB, Jun 17, 2006
  6. JB
    deadmail Guest
    In case the directions weren't that clear, after the heathrow spur and
    tunnel, head for T1. Rather than going for departures (up the ramp) stay
    to the left. Bikes park under the ramp that you're riding alongside.
    If you keep going you'll go past the NCP carpark exit and there's
    another bike parking area here. This one is less busy although I've
    only ever used it at 6.00-6.30 AM arrival.
  7. JB
    simonk Guest
    The tube? T4 station is closed until September, so it'd be some
    bus-replacement service, in which case it'd probably be worth getting the
    normal shuttle bus used for transfers between terminals.
    Anyhow, from www.baa.co.uk:
    "Motorbikes
    Motorbikes can park free of charge at Heathrow in dedicated motorcycle parks.
    Motorbikes should not use car park bays.
    The locations of the dedicated motorcycle parks at Heathrow are as follows:
    * Terminals 1, 2, 3 - at the back of Short Stay Car Park 1A/5, located to the
    right of the exit. Access is via Chester Road.
    * Terminal 4 - opposite the arrivals forecourt.
    Please note that for security reasons all motorbikes will be removed if not
    parked in the designated areas"
    simonk, Jun 17, 2006
  8. The Heathrow Express still serves Terminal 4. The slower Heathrow
    Connect service does not. The internal T123 - T4 trip on HEX remains
    free of charge as is all public transport within the local Heathrow
    Zone.
    The Tube is presently closed at T4 with a shuttle bus operating from
    Hatton Cross Station. Expected re-opening date is sometime in September
    this year.
    Paul Corfield, Jun 17, 2006
  9. Yes. Pass the drop-off point, and under the raised section there's a
    free bike park (a bit like T1).
    The Older Gentleman, Jun 18, 2006
