Heathrow Parking
Discussion in 'UK Motorcycles' started by Krusty, Jul 19, 2005.
  1. Krusty
    What's the score with bike parking at Heathrow, specifically T2? All
    the info I can find points to it being available & free, but it's not
    clear if there are bike bays in all the short-stays, or just 1A, or
    bugger knows where.
  2. The free parking is actually under T1, but that's right next door to T2,
    so it's just a short stroll.
    Head for T1 after going through the tunnel, and bear to the right of the
    inclined ramp leading up to the higher level.
    All the bikes are parked under the ramp. It's not like there are proper
    marked-out bays.
    The Older Gentleman, Jul 19, 2005
  3. Krusty
    Marvellous - cheers kindly.
  4. Krusty
    simonk Guest
    Don't take the MV - bikes are crammed into the bays at heathrow like
    sardines ...
    simonk, Jul 19, 2005
  5. Krusty
    The MV should be at base camp in Switzerland by the time I get to
    Heathrow - I'll be on the Tiger. Squeezing that in could be fun if it's
    a bit tight - bloody girt lardy thing.
  6. Krusty
    dwb Guest
    Just a question, but why not take the train to Reading and get the Air link
    coach? A bit hoi polloi I know but it works well and would remove a lot of
    the hassle.
    dwb, Jul 19, 2005
  7. Krusty
    deadmail Guest
    It's to the left of the ramp for terminal 1 departures.
    But the parking under the ramp is crowded. If you carry on that road to
    almost the end of the NCP car park (the road is between it and T1) then
    there's more bike parking just after the exit of the car park. A much
    more civilised place to park.
    There is proper marked out bike parking on the other side of the NCP
    park (i.e. follow around the road mentioned above and then take a left
    near the second entrance to the NCP) but I've never used it so don't
    know if it's free or not.
    deadmail, Jul 19, 2005
  8. Krusty
    simonk Guest
    Shame. I was going to offer to let you leave it in my garage ...
  9. Krusty
    Kiran Guest
    uh huh...
    Kiran, Jul 19, 2005
  10. Krusty
    ts Guest
    There should still be a specific area just to the left of the ticket
    barriers for cars entering into the multi storey car park down the road
    (& to the right) from the loading/unloading area outside T2. I used it
    this spring, and will be aiming for it again on Friday.
    There also presumably still are bike specific areas (free) on the ground
    floor in the car park opposite T3; as well in a third multi storey
    building downstream from T3 on the way out. But I haven't used the
    latter the last year. I think it was refurbished between one and two
    years ago.
    ts, Jul 20, 2005
  11. Krusty
    That does sound much more civilised. So it's through the tunnel, head
    for T1, go to the left of the ramp (not up it) & carry on til I see
    bikes, yes? Would that be Croydon Road or Cranwell Road on <url:
    http://www.streetmap.co.uk/newmap.srf?x=507500&y=175500&z=2&sv=507500,17
    5500&st=4&ar=Y&mapp=newmap.srf&searchp=newsearch.srf&ax=507500&ay=175500
    Krusty, Jul 20, 2005
  12. Krusty
    That would mean getting a taxi to the station, then a train to Reading,
    then a coach to Heathrow, then the same in reverse when I get back?
    Doesn't sound like less hassle than just jumping on the bike to me,
    although it probably would be if I didn't have hard luggage to leave my
    helmet/boots/jacket in.
  13. Krusty
    Blimey, there seems to be a positive plethora of options!
    It does indeed, thanks.
  14. Krusty
    zymurgy Guest
    www.motorcycleparking.com/airport_parking.htm
    Flew to Glasgow last week, and now wish i'd taken the bike to Heathrow
    rather than the Rail Air fiasco bus.
    Paul.
    zymurgy, Jul 20, 2005
  15. Krusty
  16. On one occasion, I left my bike gear in Heathrow's left luggage office.
    Tip - if you do this, take a big bag and stuff everything in, because
    they charge by the item, and a big bag is one item whereas helmet,
    goves, jacket etc counts as more.
    The Older Gentleman, Jul 20, 2005
  17. Using the patented Mavis Beacon "Hunt&Peck" Technique, The Older
    Second big tip, watch your arrival times back home, and make sure that a
    one hour delay won't mean that you arrive after the left luggage place
    closes.
    I mean, FFS, major international airport and the left luggage place
    closes before the last flight lands.
    Cunts.
    and Ducati Race Engineer.
    Enfield 500 Curry House Racer "The Basmati Rice Burner",
    Wicked Uncle Nigel, Jul 24, 2005
  18. Blimey. Good tip, yes, indeed.
    And may I just add: Bwaaaahahahahahahahaha!
    The Older Gentleman, Jul 24, 2005
