Heated grips...
Discussion in 'UK Motorcycles' started by Spike, Nov 24, 2005.
  1. Spike
    Spike Guest
    and the wiring thereof.
    Fitted a set of Mr Oxfords finest Hot Grips last nigh. Removed large divot
    of flesh from left index finger knuckle when cutting accelerator grip off.
    Those Leatherman blades are *so* sharp. Didnt feel a thing for a good few
    seconds, and then it started hurting, and pissing blood. But I digress...
    Its wired up direct to the battery for the moment, and they work a treat.
    Mr Toastyhands was my name on the way into work this morning... But Im loath
    to leave them hooked up in this fashion. Either I will forget to turn them
    off one day, or some muppet will think its funny to switch them on whilst
    the bike is parked in the bay outside the office.
    So where is the best place to hook into a feed off the ignition switched
    electrical system of the bike? Although they dont draw *that* much power
    (about 3 amps max) I dont want to go frying the bikes loom. Would I be best
    wiring them up via a relay?...And can you buy said sort of things easily?
    Forgive the numptiness, but bike electrics mystify me...
    Spike, Nov 24, 2005
  2. I fitted mine to the horn circuit. I didn't bother with a relay, but I
    probably should have done.
    Relays are available from your local friendly motor factors. They're
    very simple to wire up. Tell them what you want to do, and if they're
    any good, they'll explain what to do.
    Wicked Uncle Nigel, Nov 24, 2005
  3. Spike
    Catman Guest
    Hooked mine into the loobman feed. I didn't use a relay, and can't really
    see the point. If Oxford thought one was needed, they would have supplied
    one since it's their control unit that will keep failing.....
    Catman MIB#14 SKoGA#6 TEAR#4 BOTAFOF#38 Apostle#21 COSOC#3 OMF#22
    Alfa 116 Giulietta 3.0l (Really) Sprint 1.7 156 TS S2
    www.cuore-sportivo.co.uk
    Catman, Nov 24, 2005
    If only you had been wearing a pair of Arco's finest "1452000 Blade
    Runner Solo Cut Resistant Gloves"... ;-)
    I hope the pain has subsided.
    Paul Varnsverry, Nov 24, 2005
  5. Spike
    Alex Ferrier Guest
    Safety Nazi!
    Alex
    BMW R1150GS
    DIAABTCOD#3 MSWF#4 UKRMFBC#6 Ibw#35 BOB#8
    http://www.team-ukrm.co.uk
    Windy's "little soldier"
    Alex Ferrier, Nov 24, 2005
  6. I raise an unbandaged digit in salute to you. :)
  7. Spike
    Molly Guest
    heh
    Molly, Nov 24, 2005
