heated grips
Discussion in 'UK Motorcycles' started by fulliautomatix, May 27, 2004.
  1. Seeing as the rest of the world is asleep, I have nothing to do but harrass
    you people.
    I'm going to build me some heated grips...because I live on a big hill and
    it gets cold this time of year...down to 0 or even -5 C and the merkins who
    build Goldwings didnt put any on
    And here is how to do it;
    http://www4.tpgi.com.au/kkmiller/bike/hotgrips.htm
    And more than you can shake the proverbial stick at:
    http://www.steliosh.net/moto/heatedgrips/
    including instructions on how to make your own from
    http://homepage.sunrise.ch/mysunrise/joerg.hau/mot/hotgrip.htm
    http://www.rrr2.de/phil/motorrad/schraub/index.html is instructions
    on making a much fancier set with stepless heater control, but it's
    in german and even http://world.altavista.com/babelfish/tr won't help
    unless you have reasonable electrical/electronic smarts. IN other words,
    if circuit diagrams tell their own story, you'll be fine.
    http://www.ebbo.org/homemade_heated_grips.html is another home-made one.
    I used to have a link to an Aussie page, a guy in Canberra I think, but
    can't find it.
    Zebee<< not me but Zebee, who knows many things
  2. It was somewhere around Barstow, on the edge of the desert, when the
    drugs began to take hold. I remember "fulliautomatix"
    Have a look at http://www.warmfit.com/html/Instructions.htm for a type
    that's worthwhile copying. Seriously, this design lasts forever, unlike
    the ordinary grip heater.
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, May 27, 2004
  3. Looks good, thanks
    I have not seen this idea before but it would be much less messy than
    mucking about with the grips.
    Do they take much longer to get hot...seeing as it has to heat the handlebar
    tube and all that before you feel it?
    fulliautomatix, May 28, 2004
  4. It was somewhere around Barstow, on the edge of the desert, when the
    Just a little bit longer, but not much. It's basically a ceramic
    wirewound resistor mounted in end blocks made of hightemp rubber of some
    sort. They just slip in and are controlled by a series/parallel switch
    for two heat settings.
    I bought a set of these years ago and they've went from bike to bike
    with me. Something you can't do with conventional heated grips.
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, May 28, 2004
  5. fulliautomatix
    rb Guest
    rb, May 28, 2004
