Heated grips or handlebar muffs?
Discussion in 'UK Motorcycles' started by Eatmorepies, Nov 11, 2003.
  1. Eatmorepies
    Eatmorepies Guest
    Years ago I used handlebar muffs - they were excellent if a little bulky.
    Now I'm older and less poor I am considering heated grips - are they as good
    as muffs?
    John
  2. Eatmorepies
    Stu Guest
    They're not as effective IMHO - the backs of your hands get cold still, and
    the wet still gets in. I've used both, but have gone off the muffs as I
    found it difficult to get to the brake lever at times, and no amount of
    adjusting them could solve that.
    If you're going to get hotgrips, go for the Daytona ones. I have those and
    they're excellent. The Oxford Hotgrips are shite on a grand scale.
    Stu
    XJ900
    YTC#11 OSOS#23
    pull my plonker when replying
    Stu, Nov 11, 2003
  3. Eatmorepies
    flashgorman Guest
    If you're riding through the winter no matter what then you'll need both if
    you want to not suffer. If you just want to arrive without actually losing
    any fingers then either would suffice.
    flashgorman, Nov 11, 2003
  4. In uk.rec.motorcycles, Stu said:
    Shite as the grips are, Oxford muffs have a stiff wire bit that goes
    round the front to stop fouling of the brake and clutch levers.
    Only at high speed did I find reaching the levers an issue. If I was
    that bothered about it I would have made a hole on the side of the muff
    and stuck the bar end through it.
    Deffo Daytona, they cost a bit extra but well worth it IMO.
    Couldn't agree more about the Oxford grips. Bag o' shite, they are.
    Whinging Courier, Nov 11, 2003
  5. What he said. I've got heated grips on the Trumf and they're great, but
    the outsides of your hands still get cold.
    The Older Gentleman, Nov 11, 2003
  6. Eatmorepies
    Sean Doherty Guest
    the outsides of your hands still get cold.[/QUOTE]
    I've got heated grips and hand guards on the F650. A winning
    combination.
    Sean Doherty, Nov 12, 2003
  7. Eatmorepies
    Stu Guest
    Swot I did, and played around for ages trying get them right. I used them
    for several months but had a "moment" in central London when a ped walked
    out in front of me and I couldn't get my fingers onto the brake lever.
    Stu
    XJ900
    YTC#11 OSOS#23
    Stu, Nov 12, 2003
  8. In uk.rec.motorcycles, Stu said:
    ISWYM. Makes you look a bit slow on the reaction times ;-)
    Was it a "work" bike or one that you can modify to your tastes?
    Whinging Courier, Nov 12, 2003
  9. Eatmorepies
    flashgorman Guest
    I remember a cutting in PB that said "New Oxford Rigid Muff. Prevents wind
    pull on leavers". Class.
    flashgorman, Nov 12, 2003
  10. Eatmorepies
    Or even "levers". Classier.
    Pip, Nov 12, 2003
  11. Eatmorepies
    flashgorman Guest
    Umm. It was "leavers" actually. The point being that you don't want wind
    problems when leaving a muff - rigid or otherwise.
  12. Eatmorepies
    OIC.
    I think.
    Are you having trouble breaking?
    Pip, Nov 12, 2003
  13. Eatmorepies
    flashgorman Guest
    Only when I take my cheavy to the leavy.
  14. Eatmorepies
    Stu Guest
    My own bike - oddly enough the Met won't let us fit muffs. Mined ewe the
    Pans have the excellent Honda heated grips and the extra wind deflectors.
    Stu
    XJ900
    YTC#11 OSOS#23
    Stu, Nov 12, 2003
  15. In uk.rec.motorcycles, Stu said:
    I've seen bikes out there that have a metal rail that goes round the
    levers, like a crash bar for levers if you will. If I really wanted to
    sort the problem of not being able to reach for the brake in a hurry I'd
    go out and buy some, fit them and then stick the muffs on top.
    Failing that I read in the RD that moto-x knuckle guards were good
    underneath bar muffs, keeping them open and providing an air pocket for
    the warmth that the grips provide.
    Personally, I'd go for the crash bars for levers route but then I used
    to wear fingerless gloves anyway.
    Whinging Courier, Nov 13, 2003
