Headshake causing a headshake...
Discussion in 'Australian Motorcycles' started by Dave Ello, Nov 14, 2003.
  1. Dave Ello
    Dave Ello Guest
    Hi all,
    This afternoon, Lisa and I loaded up the XX and rode south down to Nowra.
    As many of us do, I often sit up and drop the arms on a roll down a hill,
    fully releasing the bars and relaxing.
    Today, we were cruising down a hill in a bit of traffic at about 60 and I
    did the above and within seconds, the front started to shake badly and
    almost went into a tankslapper. Until I released the bars, there was no
    hint of front end vibration or wobble. To me, this rules out throwing a
    weight. I tested this a few more times and it did start to shake a little
    at the lower speeds, but seemed OK at highway speeds. While holding the
    bars, the bike was perfect all afternoon.
    We were a little loaded and the topbox was quite a bit heavier than usual
    (~7kg), so I thought that this could have lightened the front end a bit
    (though weakened the rake). Tyre pressures are right, tyres are perfect and
    wheels have just been stringlined.
    Should I have the head bearings looked at? What's likely to cause this?
    Clearly it would be easy to suggest never releasing the bars (I've been
    doing it for years on pushbikes/mcycles and it's quite a habit) but I'm more
    interested in seeing why it's suddenly started. Tomorrow I'll try it with
    no gear or wife on board and will pass on any findings.
    Anyway, thanks if anyone has any ideas and I'll keep you posted.
    Cheers,
    Dave ZZR600 => ST2 (stolen) => '03 XX
    P.S. Our spin through the National Park had no (zip, none, zero...) cars;
    Macquarie Pass - a couple of cars that we caught pretty much at the pie
    shop, so completely unhindered; Fitzroy Falls - again, no cars at all;
    Kangaroo Valley to Nowra - caught a line of about 20 cars following a truck
    heading up to the top of Cambewarra Mtn and passed the lot of them on the
    final straight (overtaking zone) before the top - so the whole mountain was
    again devoid of vehicles as far as we were concerned. And some people have
    suggested (ludicrously) that we would never need the power of the XX.
    Awesome! Lisa *didn't* even kill me, despite our speed delving deep into
    spanking territory.... ooohhhh - whooo'se yer daddy. :)
  2. On 14/11/03 8:43 PM, in article
    bp284m$1k1v6j$-berlin.de, "Dave Ello"
    <> decided to come out from under the bed
    and slurred:
    Oh dear, its time to split the cases! Shes rooted!
    Hammo
    Hamish Alker-Jones, Nov 14, 2003
  3. Dave Ello
    Dave Ello Guest
    Leave my wife out of this you cheeky bastard. She'll kill you... :)
    Actually - you're probably right - she's got 4 months and 7000 clicks on her
    now so probably ready for a decent probing - and same for the bike.
    Cheers,
  4. Dave Ello
    Nev.. Guest
    Mine does the same, between about 70 and 80kph, only when the back is loaded
    up with luggage.
    Nev..
    '03 ZX12R
    '02 CBR1100XX
    Nev.., Nov 14, 2003
  5. Dave Ello
    Dave Ello Guest
    Thanks Nev,
    Hmmm - good to know. The only thing that makes today different was that the
    topbox was pretty heavily loaded. We are often much heavier than today -
    but weight more centrally loaded. I usually put the heavy stuff in the
    tankbag or bottom of the panniers but we had a big item to take (I'm not
    referring to Lisa's bum - we have to take that all the time...). :)
    Got a bit of a shock - we were in traffic at the time and the damned thing
    began the death oscillations! Not joyous but all is well that ends well.
    Cheers,
  6. Dave Ello
    smack Guest
    Maybe Lisa is bulking up
    smack, Nov 14, 2003
  7. Dave Ello
    MikeH Guest
    I'll be interested to here where you get to on this one Dave as I've noticed
    similar attitude. Once I had hands just off bars to get circulation again
    and the front started to waggle. Caused a bit of concern but it only
    happened at low speed and decellerating. Haven't persued it further yet.
    MikeH, Nov 14, 2003
  8. Dave Ello
    Peter Guest
    Dave,
    You might recall me alerting you to this potential problem when you first
    got the Budgie as I had experienced it on mine as well.
    In my case, it usually occurred whilst decreasing speed from around 80kph
    through to about 60kph. It tended to be worse when the front tyre was
    showing some wear and when I was carrying a pillion. I suspect that the Givi
    panniers (and contents) are exacerbating it in your case.
    The "solution" is to replace the roller steering head bearings with tapered
    bearings. It doesn't actually solve the problem but effectively masks it and
    cost around $200. Well worth the investment IMHO.
    Hope this helps
    Peter
    Peter, Nov 14, 2003
  9. How does the change from roller to tapered solve this problem? I can
    understand that if they are worn, or not torqued correctly. I know you said
    it masks it, isn't that an admission that its just a band-aid solution?
    Cheers
    Hammo
  10. Dave Ello
    FuTAnT Guest
    Take it out to Frank Pons ans get your suspension sorted :p That'l do it! I
    turned my 954 from tank slappin bitch into a stable table. Oooooooooh yeh!
    Cam
    '03 954 (solid as a rock now!)
    FuTAnT, Nov 14, 2003
  11. Dave Ello
    John Littler Guest
    I'd be betting $10 that's the cause - you need sufficient weight on the front to
    keep it stable hands off - it's why TRX's are prone to it. Did you up your
    preload ? Adding on some more preload when you add additional weight is a good
    idea and will stop the back squatting and hence extra bike weight transferring
    to the rear.
    JL
    John Littler, Nov 14, 2003
  12. Dave Ello
    glitch1 Guest
    First thought:
    suspension ( right preload for the weight at back?)
    Second:
    tyres, most precisely: the front.
    had similar on the Bandit12 (after the firsat 3000km) until I changed to a
    Metz Z4, which took the shakes out completely, right through the life of the
    tyre.
    my 0.02c
    cheers
    pete
    glitch1, Nov 14, 2003
  13. Hi Dave,
    Maybe a bit more preload on the rear to shift weight forward a little ? Less
    weight in the top box? How warn are the tyres
    and finally, I wouldnt really worry about it, bikes the size of the XX and
    Zed are a delicate balance between mundane cruiser handling and sports like
    nimbleness - the trade off is they are vunerable to headshake under less
    ideal weight distribution.
    Nothing to really worry about - just keep the hands on the bars if you cant
    dial it out
    Baron Von Rotter, Nov 14, 2003
  14. Dave Ello
    Gary Woodman Guest
    Just what does this mean? My Beemers need an extra 10-15% air in the rear
    with a pillion, and another 10-15% with a decent load, or the rear end
    wallows everywhere and the front shakes frantically...
    Keep us posted!
    Magic!
    Gary
    Gary Woodman, Nov 15, 2003
  15. Dave Ello
    Biggus Guest
    Hmmm - good to know. The only thing that makes today different was that the topbox was pretty heavily loaded.
    Unload the top box leave the rest as it is and ride it again, see if
    thats what it was, or not..
    Biggus, Nov 15, 2003
  16. Dave Ello
    Biggus Guest
    You wouldnt be Rich's with the hirebus mate from shitney that moved to
    melbourne??
  17. Dave Ello
    Trips Guest
    Hows this for fscked up. Whenever I put on my jacket I get headshake
    outya the CBR because the jacket acts like a parachute and causes my
    arms to shake the bike!
    Trips, Nov 15, 2003
  18. Dave Ello
    Smee Guest
    Too much weight on the rear.
    (no dig at the missus either.)
    Smee, Nov 15, 2003
  19. Dave Ello
    conehead Guest
    You ride hands-free in traffic? You're a devil, Dave.
    conehead, Nov 15, 2003
  20. Dave Ello
    conehead Guest
    <snip>
    Blinkers and a shadow-roll often settles flighty steeds down.
