Headlamp bulb compatibility
Discussion in 'Motorbike Technical Discussion' started by fac01, Jan 29, 2004.
  1. fac01
    fac01 Guest
    I have a 1999 Honda CBR 600 F4 and need a headlamp bulb for it. When I
    examine the bulb, I see the markings 'H4' and 55/60w. When I ask at my
    local shop, they say that they do not have the bulb in stock, and it
    will be about $30 each to special order them. Does anyone know if
    these are standard auto bulbs I can buy at any auto parts shop or are
    they motorcycle specific? I went to Pep Boys today and saw that the
    Sylvania 9003 bulbs appear essentially identical, but there is no
    cross-reference source in the store or online I can use to verify that
    they are the same. Also, the bulbs are only $10 at Pep Boys. Any help
    or advice would be appreciated. Thanks in advance.
    fac01, Jan 29, 2004
  2. fac01
    OH- Guest
    Any H4 55/60W will do. H4 is a standard that describes the shape and
    wiring of the bulb.
    Not all bulbs, not even standardised ones are born equal. They will
    fit and function but "colour", light intensity and sensitivity to vibrations
    will vary. Don't worry, just get a bulb from a reputable brand, it will
    be fine. Even on my thumpers and dual sport bikes I've always used
    standard bulbs and failures have been few and far between.
    OH-, Jan 29, 2004
  3. fac01
    harrison Guest
    saw that the
    If you look carefully at the base of a Sylvania 9003, you should see H4
    marked on it. Same bulb, sometimes found for about $7US at discount stores.
    Common as dirt. My Triumph and older BMW both use them, as did a V*lv* I
    once owned.
    98 BRG Triumph Sprint Exec, 82 Red BMW R65
    Remove "WOW" from email address if replying directly
    harrison, Jan 29, 2004
  4. fac01
    Mark Olson Guest
    According to partsfish.com, the Honda part number for your bike's
    bulb (assuming the '99 CBR600 F4 has a single, not dual, headlight)
    is 34901-MC7-601, partfish's price: $6.17.
    Googling for 34901-MC7-601 turns up at least one link that says it is
    a standard 60/55W H4 bulb.
    Is the $30 price from a Honda dealer or an independent shop? Either way,
    I'd find somewhere else to buy parts. I like checking partsfish.com's
    price as a sanity check before I call the local Honda dealer. It's worth
    calling around, prices on genuine Honda parts vary widely from dealer
    to dealer, and I have found there isn't usually a single local dealer
    that is always the cheapest.
    Mark Olson, Jan 29, 2004
  5. fac01
    Page Guest
    However, you better make sure your wiring, fuse, and alternator will
    handle the load. At 60W you are pulling about 5 amps with a 100W it's
    about 8.4 amps. Power (watts) = Voltage (E) * Current (I) or (P=E*I),
    therefore P/E = I. 60W/12v = 5a, 100W/12v = 8.33a. For the load on the
    alternator you have to add up all the current draw of the bike and allow
    for a 20% headroom. Plus, I don't know what the legal limit is for Texas.
    Page
    '01 FXDWG, NTXNS
    "Happy Hour" starts one twist of the throttle past neutral!
    Remove the 123 to reply.
    Page, Jan 29, 2004
  6. fac01
    Hank Guest
    interested to see if partsfish's bulb would say genuine honda 34901-MC7-601
    or made in taiwan. Buy the Pep boys H4 ,preferably in 100+ watt version.
    Hank, Jan 29, 2004
  7. fac01
    Hank Guest
    I think the legal limit almost everywhere is 60/55. What cop is going to
    check? (remember this requires brains & effort) Any jap bike should be able
    to handle the extra load. I have 120/80 in my ol GL1000, and CBR600. Make
    sure it is aimed correctly to avoid hassles from cops & other motorists
    Hank, Jan 29, 2004
  8. fac01
    fac01 Guest
    Thanks everyone for the help and advice. I'm planning on going out and
    buying the Sylvania bulb later today and a spare since my Honda Civic
    uses the same bulbs. The store I asked for a quote from was a chain
    motorcycle supplies/parts store called Cycle Gear. I've bought a
    number of items from them before and have always been happy, so I
    think this was an exception. Just one last question, though - M.J.
    Freeman a few posts ago recommended the Hella 80/100 watt bulbs. Is
    there any problem with overheating/melting the housing or damaging the
    electrical system with this bulb? Thanks again.
    fac01, Jan 29, 2004
  9. 9003 will work.
    my honda dealer had h4's for $5.95.
    William Mahoney, Jan 30, 2004
  10. fac01
    OH- Guest
    Not only that. The heat from a high wattage bulb may destroy
    the reflector. So after some time, the light output will be no better
    than with the original bulb.
    On many bikes the headlight wiring is a joke. Thin wires and bad
    switches. A good way to increase the light is to supply the bulb
    with the correct voltage. Thick wires straight from the fuses,
    controlled by relays.
    OH-, Jan 30, 2004
  11. fac01
    Rein Guest
    hmm, don't fall for that one. The last time I walked into a small
    auto-parts store they had 3 different sylvania models that fit the H4
    standard. One was stock H4, the other two were 'premium' (or whatever
    they called them) models that gave more light. Cheapest one was 8
    bucks, most expensive one was 15 bucks I think.
    Remove NO-SPAM from email address when replying
    Rein, Feb 1, 2004
  12. fac01
    OH- Guest
    As I was the one uttering on of the "dire predictions" I think that a
    clarification is called for.
    Some people are very sure that they know everything. They will
    state things like Lefty "If you use a bulb that pulls 80/100 watts, the
    current will melt the wires". No qualifiers, no "IMHO", no mention
    of where or when that experience was gained.
    If we go to my warning about the reflectors, it said there _may_
    be a problem. I'm really trying to make postings that does not
    state things I'm not reasonably sure about. If something might
    be true or if I suggest a course of action that is more of a hunch
    that solid knowledge I try to make that clear.
    It's quite common that people want "straight answers" (especially
    the ones that come here once only to get help and has nothing
    to contribute). OK, it happens once in a while that the problem
    has a simple answer that someone here can post. More often, it
    is the same here as in all engineering, you need to get a couple
    of opinions, try a few things and find a solution that might not be
    the one and only truth but it will work.
    And because this isn't brain surgery, I've run a 80/100 W bulb
    in my XT. No dire consequences, but no great success either,
    probably because the feeble wiring had too much voltage loss
    even if nothing got burnt.
    OH-, Feb 2, 2004
  13. fac01
    Hank Guest
    FWIW I have been running these 120 or 140 or 100/80 bulbs for over 15 yrs in
    my 1987 CBr600 without the burnt up switches, wiring, or reflectors
    predicted here. My "new" GL1000 and also the one I had before the CBR,
    ditto. The lacklustre performance of hipower bulbs in your XT is likely the
    fault of your alternator design, not the wiring. Dirt/dualpurpose and ATV's
    frequently make just enough power for stock lighting and not a milliamp
    more.
    Hank, Feb 2, 2004
  14. fac01
    OH- Guest
    "Hank" <> skrev i meddelandet
    Now, the XT has a decent alternator even if it's not designed to power a
    stereo, half a dozen driving lights and a small fridge.
    Now, the wiring might work (and is essentially the same as a few Yamaha
    street bikes I've had) but it sure isn't a decent way to power supply a
    halogen bulb. The wire itself is small gauge (compare it to car wiring for
    the same application), the current passes 3 switches (and they are not
    fancy ones either) and a number of cable connectors (not exactly gold
    plated stuff). Now, knowing how voltage sensitive the light output is, it's
    a minor miracle that even a 55/60W bulb works reasonably well.
    Other bikes obviously has a better laid out system and will work
    better with high wattage bulbs. That is why I mentioned the bike
    model. My message is that you should consider some things before
    changing to high power bulbs and not just assume "bigger is better".
    Your point about alternator output is another good thing to
    consider.
    By the way, we usually post answers below quoted text.
    OH-, Feb 3, 2004
