Headers
Discussion in 'Motorbike Technical Discussion' started by LSMFT, Apr 10, 2011.
  1. LSMFT
    LSMFT Guest
    Why are my chrome headers turning a nice golden color where they connect
    to the engine for about 8 inches? 1996 Suzuki 1400.
    LSMFT, Apr 10, 2011
  2. Because they get hot.
    Are they the originals or aftermarket ones? After 15 years, could be
    either.
    The Japanese tend to make their chrome header pipes double-skinned to
    prevent them discolouring (blue or yellow) with heat. Pattern
    manufacturers are not usually so painstaking. Single wall tubing
    discolours.
    If they're the originals, then the mixture is wrong and the engine is
    running seriously hot.
    Krusty will be along in a minute to tell you what they used on 1970s
    Suzukis.
    The Older Gentleman, Apr 10, 2011
  3. LSMFT
    ` Guest
    High temperature oxidization.
    Even stainless steel headers will turn color, they become brown.
    `, Apr 10, 2011
  4. LSMFT
    ` Guest
    Bullshit.
    `, Apr 10, 2011
  5. LSMFT
    LSMFT Guest
    I assume they are original since it was fairly new when I got it. Had it
    a long time now. You know how you lose respect for things after you've
    had them a while. Not so gentle any more. The manual says it will go 40
    in first, 67 in second and 93 in third. I think I tried it a couple
    times in the last two years when pissed off. Mighta got hot.
    LSMFT, Apr 10, 2011
  6. LSMFT
    ` Guest
    It's *normal* for an exhaust header to reach temperatures of up to
    1400 degrees F.
    Read the explanation of why the chrome turns colors at the bottom of
    the page.
    http://www.webbikeworld.com/r3/blue-job/blue-job-chrome-polish.htm
    `, Apr 11, 2011
  7. LSMFT
    LSMFT Guest
    LSMFT, Apr 11, 2011
  8. LSMFT
    ` Guest
    Some mud splattered on the front exhaust pipe of my SV650S and that
    prevented oxygen from getting to the hot metal evenly.
    So the exhaust pipe is kind of mottled gold and purplish brown.
    I'm not laying awake nights worrying about it.
    `, Apr 11, 2011
  9. No, accuracy. Weak mixture means extra heat. Duh.
    The Older Gentleman, Apr 11, 2011
  10. Stainless goes yellow, chrome can go blue, I've seen yellowish chrome
    headers. It's a matter of heat, which is why, as I said earlier, the
    Japanese double-skin their chromed headers (which Krusty evidently
    doesn't know).
    My old BMW airheads always blued their headers because BMW didn't
    double-skin them, for lightness.
    No idea whether the OP's bike has chrome, stainless, titanium or bronze
    headers, but unless there's excessive discolouration, it really isn't
    anything to worry about, as you say.
  11. *Yes*. Now guess why the Japanese double-skin them, on chromed systems.
    Krusty gets it wrong again.
    Snake oil. And it didn't work on their BMW headers. Try and figure out
    why not.
  12. Not really a problem. On double-skinned chromed headers, as I said
    earlier, discolouration - serious blueing - can be a sign of something
    getting a bit too bloody hot.
    As for the OP - just realised I've posted something misleading. Golden
    headers, unlikely to be a prob. Blue can be yer enemy.
  13. God knows. No idea, really. I'd imagine they'd keep to chrome on
    cruisers and the like, because the magpies like it, but your guess is as
    good as mine.
    Agreed. Sometimes it goes wrong. Not so long ago, I saw a Honda CB400
    Four, one of whose downpipes had been replaced with a pattern
    (single-skinned) item, and it was the only blue header of the set. Just
    didn't look right.
    Gilded? ;-)
    I've seen it done, at French endurance races, during the interminable
    killswitch-backfire battles. Never had the mechanical lack of sympathy
    to do it myself ;-)
  14. LSMFT
    ` Guest
    Don't confuse Neil Murray with the facts. He wants to believe the old
    bikers' tales about lean mixtures or rich mixtures that result in fuel
    burning in the exhaust header.
    `, Apr 11, 2011
  15. Wrong *again*!
    Utterly amazing, isn't it? You can't get *anything* right. Look up the
    difference between a weak mixture making an engine run hot, and fuel
    burning in exhausts.
    Coming from the man who claims to receive some 400 emails a year,
    praising and thanking him for his advice.....
  16. LSMFT
    ` Guest
    Let's put it another way so you can understand it.
    *Cosmetic changes in surface treatment appearance do not necessarily
    equate with tuning problems of stock engines*.
    If you can twist *that* statement some other way, then *sit on it and
    spin* until you get your grins.
    You lying asshole, I never quantified the amount of grateful responses
    I get from newbies.
    `, Apr 11, 2011
  17. "An engine running un-naturally hot will discolour chrome"
    There!
    See above.
    Here we go again.
    Yes, you did.
    You said you get emails *every day*. There are 365 days in a year.
    That's 365 emails a year, so some 400, plus a very few to allow for more
    than one grateful newbie.
    Would you like me to copy and paste your original posting, so you can
    check the maths?
    Here you go:
    "I get appreciative thank you notes by email every day from riders that
    I've helped with their problems." Posting made 5 April.
    Would you like to check it on Google Groups?
  18. LSMFT
    ` Guest
    *Sit on it and spin* until you get your grins.
    `, Apr 11, 2011
  19. I'll take that as the standard Krusty acknowledgement that you've been
    made to look a liar and a fool *again*.
    Bwaaahahahahahaha! Every time, every time....
  20. LSMFT
    ` Guest
    The only "un-naturally hot" thing around here is *your asshole*.
    Cool it off with Preparation H...
    `, Apr 11, 2011
