Head shake
Discussion in 'Motorcycle Technical Discussion' started by Scott, Jun 4, 2006.
  1. Scott
    Scott Guest
    To be determined.
    Define "old". I never had a tire last more than three years on that bike.
    -Scott
    Scott, Jun 5, 2006
  2. You really *really* don't know this country.
    The Older Gentleman, Jun 5, 2006
  3. Oh FOR ****'s SAKE! Again with this cure-all?
    Make the steering quicker on a bike that's already giving him grief?
    You know, you're a worthy successor to the late great Hoyt sometimes.
  4. He didn't use an upper case P, so he may or not be referring to the firm
    by that name. There are other manufacturers.
    This assumes that the aftermarket spring doesn't have more widely spaced
    coils elsewhere
    On old CB900s and the like, you just used to pour in the recommended
    quantity and not measure air gaps etc. Not that I'm denying that it's
    the right way of doing things, mind.
    Yes. Never seen it happen. You'd have to seriously overfill the leg to
    get it that bad.
    Look, for years, if not decades, I've known people who've used
    aftermarket fork springs and read articles, ranging from small postings
    to large technical treatises, recommending them.
    I've used them, and thery made a big difference. Massive improvement.
    Considering how cheap they were, it was one of the best value mods I've
    ever done.
    And you're telling the world it's wrong and you're right? That's a wee
    bit arrogant.
    You're posting a lot of informed and accurate tech stuff and you are
    also drawing a lot of wrong conclusions and also omitting as much stuff
    as you post.....
  5. I'd take any of that over the parking lot at Home Depot.
    Went there the other day, was idling out of the lot getting ready to
    take a right turn, going about a mile and hour, put just a slight bit of
    front braking on and without warning the bike went down.
    Stood up to get the bike up and nearly went down myself. Looked down
    and the pavement was slick with oil. We aren't talking drips from cars
    here, we are talking 2-3 quarts of 10W-40 poured out onto the lot amounts
    of oil. Fucking bastards and their shit cars why don't they get the damn
    things
    repaired!
    Unfortunately it had been raining earlier so there were puddles all over
    the lot, that's why I missed this one.
    I agree, I go over lots of really cruddy city roads as well as steel grate
    bridges, and when I hit pavement that's badly grooved the steering
    head always wobbles a bit.
    If you look at that video of the guy riding over the 8 foot deep pond
    that was posted in the rec.motorcycles group last week, the front
    steering wobble is -extremely- evident.
    Ted
    Ted Mittelstaedt, Jun 5, 2006
  6. Scott
    FB Guest
    It sounds like you've never actually pulled the forks up through the
    triple trees to get more front tire grip. Try it, you might learn
    something.
    Although the machine will turn in quicker, the steering feel is heavier
    because there's more traction. The front end doesn't begin to shake so
    easily, and speed weaves begin at higher speeds.
    How would you like to make a small wager on that, perhaps $10K USD?
    FB, Jun 5, 2006
  7. I have, I have. I'm still far from certain I'd want to do it on a 1970s
    era 900.
    Well, indeed.
    chateau.murray, Jun 5, 2006
  8. Scott
    FB Guest
    That method is a lot more reversible than cutting the frame and
    re-positioning the steering head.
    FB, Jun 5, 2006
  9. Sigh.
    Or you could do what Honda did and just bolt a bloody great lump of cast
    iron (10lbs plus) onto the front forks.
  10. Scott
    FB Guest
    Here in the USA, Progressive Suspension has hijacked the generic term
    for a spring that is wound progressively.
    Back in the 1970's, Japan Inc. was springing motorcycles so they could
    carry about 500 pounds of rider and passenger. Even the little commuter
    bikes were sprung ridiculously stiff.
    My GT-750 Water Buffalo had 44 pound/inch straight wound springs, as I
    recall and it seemed to be perfectly sprung in the front. I had a lot
    of confidence in the handling of that machine.
    But then Suzuki, in its incrutable wisdom, installed 24 lb/in rate
    springs in the front end of my GS-1100.
    OK, so the GS-1100 had about 25% more fork travel. Logic would imply
    that you could use a 33 pound/inch straight wound spring in a machine
    that weighed about as much as the Water Buffalo.
    Riders have a hard time predicted the necessary steering input when a
    fork is stroking through long travel. That's why the enduance racers
    wanted anti-dive suspension and that's what they got with the GS-1100
    with its compression blow off valves.
    But the forks still moved up and down too much for the taste of a lot
    of riders. That's why they installed stiffer progressively wound
    Progressive Suspension springs.
    As the closely wound coils collapse and bind on each other, it's like
    having a variable length preload spacer to work on the remaining coils.
    No, I'm saying that Progressive Suspension makes the same spring to fit
    multiple models and that they haven't tested every possible
    installation.
    FB, Jun 6, 2006
  11. This is utter, utter nonsense. The small commuter bikes of the day were,
    in the main, sprung too softly. My Honda CD175 could be bottomed out
    with ease. Ditto just about every Jap bike of 250cc or under, especially
    Hondas.
    Grim memories of CB250G5s, CJ250s, and the like.
    Of course, "little commuter bikes" may mean 400cc+ in the US, but for
    the rest of the world, it means 250cc and under and in that bracket, you
    really are talking crap.
    The Older Gentleman, Jun 6, 2006
  12. Scott
    FB Guest
    But you weighed *twice* the designed solo rider weight.
    Hondas are light duty, disposa-cycles.
    When you talk to a Californian about a "commuter bike" he may living 50
    miles from work and be thinking about the possibility of braving the
    freeway traffic jam on nice days in order to "save" money on gasoline.
    But to Euros, a "commuter bike" might be a 49cc moped capable of
    zipping through lines of traffic so he can ride 6 kilometers home for a
    two hour lunch.
    FB, Jun 6, 2006
  13. For ****'s sake. You do yourself no favours, you know that?
    Let's start with weight - who says I weighed twice the design weight?
    You mean I'm twice as heavy as a Jap (or was)? At the time, that was
    unlikely and secondly....
    ...well, I remember overhearing some arsehole at a bike show
    knowledgeably explaining to his mate that the trouble with Jap bikes was
    that they were designed for Japs and therefore didn't fit westerners.
    The Japanese design for export markets, you know.
    In fact, for a hell of a long time, big bikes were not intended for the
    home market at all because of the Jap licence limits and their odd bike
    test requirements which stated that you had to be able to pick the bike
    up from lying-on-its-side. And not many could pick up (say) a Z1.
    Secondly, your Honda comments. So derisory I'll leave them.
    Thirdly, your idea of European riding.....
    It's true that a helluva lot of Nifty Fifties are sold over here. That's
    because they're ideal town transport - no jams, free parking, and we're
    allowed to lane-split. Economical, too - remember our juice is highly
    taxed and so costs about US$8.50 per (imperial) gallon. Oh, and you're
    allowed to ride them at 14 in some countries (though not the UK).
    But this appears to be the recurring theme in your discourses: sweeping
    generalisations that, if qualified, might have some truth in them, but
    which otherwise come out as a kind of Usenet long drawn-out fart. "Brits
    don't know about sports bikes because they don't have the roads for
    them" sort of thing.
    I mean, I know a lot of people who say the Yanks can't ride for toffee
    because all their roads are straight - and that's rubbish too.
    "Jap commuter bikes were too stiffly sprung" - I mean, that's just
    *crap*. I wouldn't argue that their suspension was often woefully
    under-damped, but that isn't the same thing.
    Take a good long hard look at what you're posting, and pull your neck in
    a bit, because while you hit the nail on the head sometimes, a lot of
    what you post is opinionated drivel.
    Knock, knock....
    Hello, Hoyt???
  14. Scott
    James Clark Guest
    The infamous Honda "solid-state" steering damper?
    Were the ribs used to radiate heat or to improve the structural rigidity of the device?
    James Clark, Jun 6, 2006
  15. of the device?
    Heh. Who knows? Bloody lawnmower/Flintstones engineering, if you ask me.
    "It's wobbling, Soichiro."
    'Hm. Have we any depleted uranium?'
    "Too expensive. Cast iron is cheap, though."
    'OK, bolt this lump to the front forks. It'll damp something out.'
    Utterly unbelievable.....
  16. Scott
    FB Guest
    I think you and Hoyt will probably spend ten thousand years together in
    Purgatory, and then you'll decide to marry and live happily ever after.
    In the meantime, Progressive Suspension springs suck, and Dynojet kits
    are a rip off.
    And beware of your Frankenstein centrifugal starter clutch.
    FB, Jun 6, 2006
  17. Eh? If this is a reference to my Morini's Mephistophelian starter motor
    system, you're on the money.
    If it's a reference to Triumph's starter clutch problem, you're years
    out of date. They fixed it ages ago.
    In fact - and not for the first time - I can't think wtf you're on
    about.
  18. Scott
    FB Guest
    I'm "on" about my pret peeves. But you are just generally peevish.
    FB, Jun 7, 2006
  19. Scott
    sharkey Guest
    Sheesh, man, make your mind up! One minute you want them to repair
    their cars, next minute you won't even let them change their oil in the
    carpark!
    -----sharks
    sharkey, Jun 8, 2006
  20. You have no idea how much that made me laugh.
    The Older Gentleman, Jun 8, 2006
