Head Oil Leak After Rebuild
Discussion in 'Motorbike Technical Discussion' started by Tim C, Feb 20, 2005.
  1. Tim C
    Tim C Guest
    1980 Cb 650 Custom. I recently paid a shop to install new rings/valve
    stem seals/lapp valves. They charged me for a gasket kit. It leaked in
    the valve body area before and also after the rebuild. I cleaned the
    whole area the best I could and took it to another motorcyacle shop
    and even they cant tell me really where it is leaking from.
    Does anyone have any ideas as to what can be done to get this leak
    fixed. I am going to take it back to the person that did the top end,
    I wonder if he forgot to put in a few o-rings somewhere.
    I have heard of coating the top with powder and see whare it leaks
    etc, but maybe the best thing to do is to take the valve body off and
    start again?
    Advice appreciated.
    Thanks.
    Tim C.
    Tim C, Feb 20, 2005
  2. Tim C
    manjo Guest
    Tim C,
    Could be the a warped head. Just a WAG.
    Ride safe,
    Manjo 1500A9
    manjo, Feb 20, 2005
  3. It leaked in the valve body area before and also after the >rebuild. I
    cleaned the whole area the best I could and took it to >another
    motorcyacle shop and even they cant tell me really where it >is leaking
    from.
    In the case of a real leak, you will see where a stream of wet oil has
    run down the front of the engine, usually. But weeping oil is a
    unesthetic nuisance that doesn't really justify disassembly and repair,
    just occasionally wiping the oily film off the engine...
    Why did you take it to another shop? Didn't you get a warranty on the
    work done in the first shop? Or did you let the warranty on parts and
    labor expire?
    You have a right to expect the work you paid for to be done thoroughly,
    at least for the limited warranty, and getting a motorcycle back that
    leaks fluids after being worked on indicates that the work was done
    incorrectly...
    I wouldn't tell the original mechanic that I had taken the motorcycle
    somewhere else. He might claim that the other shop was at fault...
    It is very possible that o-rings were lost or forgotten during the
    disassembly and reassembly process. Mechanics are in a rush to get work
    out of their shop so they can make money for as little time spent as
    possible. I looked at the the drawings at www.partsfish.com, and I see
    that the valve cover has three gaskets on top of it and a gasket
    underneath it. They look like the rubber gaskets on my GSXR, which are
    supposed to seat in a groove in the cover. If the mechanic doesn't glue
    the gaskets to the covers, they can slip during assembly, and then they
    will leak...
    It's also a good idea to apply a thin film of silicone sealer to the
    flat side of rubber gaskets like that, to prevent unesthetic oil
    weeping...
    Also, the tachometer drive assembly has an oil seal and rubber o-rings.
    I had the oil seal leak on my GS-1100, and it wore a groove on the
    shaft that drives the tach cable, so I had to polish the groove out
    before it destroyed another oil seal and leaked again...
    Blowing talcum powder (like after shower talc) out of a plastic bottle
    onto an area where there's an oil leak sounds like a really good trick.
    You should spray gunk all over the area where the leak is
    at, hose the engine off with water and let it dry good before applying
    the talcum powder and starting the engine. The worst thing that could
    happen with talcum powder is that it blows away when you ride the
    motorbike...
    But, I wouldn't recommend having the shop remove the cylinder head
    until you've checked out those gaskets, oil seals, and o-rings in the
    valve cover, the valve adjustment covers, the oil/air separator, and
    the tach drive...
    If the leak is lower, down around the head gasket, maybe just
    retorquing the cylinder head will stop the leak. The original shop will
    probably do that anyway, before committing their time to removing the
    cylinder head a second time...
    So, if they tell you that's what they did, ride the bike right away to
    see if it leaks when it's warmed up. Don't let your parts and labor
    warranty run out before it's fixed...
    krusty kritter, Feb 20, 2005
